(diesel-rated)15w-40 for the 22re? ....(from oil post below) #812568 05/17/07 04:07 PM
P
pagan Offline OP
So,DID I READ THIS PROPERLY? Is Delvac 15-40,Delo 15-40,or Rotella 15-40 definately the preferred motor oils now for higher mileage 22re's?
(or,20w50 of the same brands)
My only real question regards the viscosity of this 15 weight oil...is it too thick for the 22re?Or is this actually better because of quicker oil pressure buildup which helps the t-chain tensioner,etc?
Thanks again for the elucidation...and sorry for what seems like a reposted topic...
-Pagan (22re 14ok w56)
Re: (diesel-rated)15w-40 for the 22re? ....(from oil post below) [Re: pagan] #812569 05/17/07 04:59 PM
4Crawler Offline
I've run the 15W40 oil in my '85, seems to work fine for me. Does not get terribly cold where I live, so don't notice the thicker oil viscosity.
Re: (diesel-rated)15w-40 for the 22re? ....(from oil post below) [Re: 4Crawler] #812570 05/18/07 02:15 AM
canuck Offline
I'm also a little confused, I live in Toronto where it's in the 80-90f range in the summer so 15w40 sounds feasable but what about in the winter when its 0-20f on a regular basis and below 0 for a few days here and there. Any thoughts..... Hey Kewlynx your next to the Yukon, whats your take on cold weather oil.
Keep the Shiney Side up. Support our troops.
Re: (diesel-rated)15w-40 for the 22re? ....(from oil post below) [Re: canuck] #812571 05/18/07 02:20 AM
kewlynx Offline
No 15w40 for me here. I weighed in on his other post.
Pagan, edit yer profile and stick yer location on there. <img src="/forums/images/graemlins/pfft.gif" alt="" />
**ubi apis- ibi salus**
Re: (diesel-rated)15w-40 for the 22re? ....(from oil post below) [Re: pagan] #812572 05/19/07 02:18 PM
rustylux Offline
You shouldn't really use diesel oil in conventional gasoline engines. It has solvents and detergents in it that wash out all the carbon and gunk that resides in diesel engines. Thats what I've been led to believe anyways <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: (diesel-rated)15w-40 for the 22re? ....(from oil post below) [Re: rustylux] #812573 05/19/07 10:22 PM
kyle-22r Offline
it's perfectly fine to run in a gasoline engine as long as its API rating has a certification for "S*"(spark ignition, like SJ, SL etc) engines.
i ran 15w40 in my truck, however it was in the winter and made the oil pump whine for a few seconds on startup in 20- weather.
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.833s Queries: 15 (0.003s) Memory: 0.6115 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-10 00:36:19 UTC
