Fuel issues #812713 05/18/07 05:19 AM
sportakee Offline OP
93 cherokee. Had problems with it sputtering when it's cold and hot, at low and high speeds and when cornering and on straight-aways. It died on me a couple times while I was driving , but managed to restart. This last time however it wouldn't. When turning ignition on, I don't here the fuel pump prime. I took hose off at filter and no gas is pumped. Engine turns over fine, there is just no fuel getting to the engine. Ideas? As well, how do you pull a pump out. Is it necessary to drop the tank? Thanks to all who may reply.
Re: Fuel issues [Re: sportakee] #812714 05/18/07 05:39 PM
Brown81CJ5 Offline
The majority of older vehicles require dropping the tank to access the fuel pump. Not too many, that I know of at least, have an access hole to get to the pump without dropping the tank.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Fuel issues [Re: sportakee] #812715 05/20/07 04:34 PM
4x4Wire Offline
The Cherokee fuel pump is located near the center-front of the tank on top. I know the 89 version fuel pump can be removed without dropping the tank.
Replacement pumps are expensive. Check for loose or broken connections.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Fuel issues [Re: 4x4Wire] #812716 05/21/07 08:41 AM
BlueXJ Offline
Also check that the pump has a good ground. Yes, as has been mentioned you can access the pump w/o lowering the tank. Much easier to do on a lift or if you have a lift on your XJ. One other thing to check is the fail-safe switch. I do NOT know exactly where yours is located but it may be going bad. Is was intended by the factory to cut power to the fuel pump in the event of a rollover and when(rarely) they go out they exibit the same symptoms as you described. Find a FSM and look up where yours is located.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5996 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-10-26 21:34:59 UTC
