Alternate amplifier locations
#813009
05/18/07 09:58 PM
IÆm trying to find a location to mount an audio amplifier for an audio upgrade in my 2004 TJ. I want to remove the carpets for some wet weather so under the seats is no good, and I have an add-a-trunk in back so there is no room there. Has anybody ever tried mounting an amplifier behind the dash?
2004 TJ Wrangler Sport
Re: Alternate amplifier locations
[Re: bradford_johnson]
#813010
05/19/07 02:08 AM
What kinda system do you plan on running? If not too big a one, you can get a fairly small amp and get like a 1 farad capacitor...2 items, but easier to find spots for 2 smaller items.
Gun it and run it! 1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
#813011
05/19/07 04:54 PM
behind the dash isnt a good idea...you still get some small water leaks back there (at least in the older TJ's, not 100% sure about the newer ones)
do you take your doors off alot? you might be able to rig it up to go into your door (there is a bit of room behind the panel)
[Re: Macdaddy4738]
#813012
05/19/07 05:03 PM
What size is the amp that you have or are planing on getting. If it's small enough you could put it in your center console if you have one....sorry I have a CJ, not a TJ...just tryin to throw some ideas out there.
#813013
05/19/07 09:44 PM
Would it be sheltered enough if you mounted it under the seat, but instead of on the floor, mount it to the bottom of the seat itself?
[Re: Chris72]
#813014
05/22/07 04:38 AM
Yeah...There should be room to mount it under the back seats. That is where i mounted my JL amp
'98 TJ, Manual, 3" Susp and 1" Body lifts, 33" BfGoodrich Mud Terrains, Winch, JET Stage 1/2 Power Module Computer Chip
[Re: kornblind9]
#813015
05/27/07 01:32 AM
How about getting a marine amp?
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
