Re: starting to install lift
[Re: DennisThompson]
#813084
05/23/07 02:13 AM
i welded the bottom coil retainers straight out the back and laid them flat but up tight to the nub all i did is spun the spring till it centered if you look close in the picture you can see the left one, as far as the tj springs they were off a hard top and i only measured 2 inches of vertical lift after i installed them i don't know what i got out of the front because i thought about measuring it after i had the jack stands underneath and tires off. But the rear ones could be wore out i do have accsess to another set so i will try those next
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
[Re: kiarazy]
#813085
05/23/07 06:25 PM
Nice Rig!!!
[Re: kiarazy]
#813086
05/23/07 06:57 PM
In your pics you rear springs look like they are compressed more than mine and mine is a 4 door. Try the other set and if they are the same I have a set of 1 1/2" or 2" spacers if you want a little more lift. Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
#813087
05/23/07 10:34 PM
OK, am I missing something? Where are his pics?
No matter where you go, there you are! "Buckaroo Banzai"
[Re: MemphisFred]
#813088
05/23/07 10:38 PM
Prolly need to check your video memory....... <img src="/forums/images/graemlins/confused.gif" alt="" />
#813089
05/24/07 03:08 AM
In your pics you rear springs look like they are compressed more than mine and mine is a 4 door. Try the other set and if they are the same I have a set of 1 1/2" or 2" spacers if you want a little more lift. Dennis ok yea i will let you know when i get around to trying those other springs
[Re: kiarazy]
#813090
05/25/07 10:27 PM
Kiarazy,were did you get your bumper????F/R,They look great>>I need them<<<< <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
[Re: victwisted]
#813091
05/25/07 11:00 PM
[Re: victwisted]
#813092
05/25/07 11:56 PM
Kiarazy,were did you get your bumper????F/R,They look great>>I need them<<<< <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" /> i may be wrong, but by the looks of it, it is a jeep bumper. if so i was going to do the same thing. all you have to do is rework some mounts for it to fit the sportage.
[Re: DEFBOY35]
#813093
05/28/07 08:55 PM
custom i made them myself its 2x6 rectangular tube, then on the front i bent the hoop on a buddies bender they were preety easy to make and i got 75 bucks in to them that included the tubing for the rock slides.
