'90 Wrangler starts fine but then sputters out and dies #813101 05/19/07 05:15 PM
hoki06 Offline OP
its starts fine but if i dont stay on the gas and rev it then the RPMs go low and low and then it dies. its a '90 with 4.2L and 2 barrel stock carb. what do i need to do?
Re: '90 Wrangler starts fine but then sputters out and dies [Re: hoki06] #813102 05/19/07 05:26 PM
Brown81CJ5 Offline
Try cleaning the idle tubes in your carb, and your entire carb for that matter. Is your fuel filter clean? Does it die after it warms up, or does it die no matter what?
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: '90 Wrangler starts fine but then sputters out and dies [Re: Brown81CJ5] #813103 05/19/07 07:44 PM
hoki06 Offline OP
its fine when it just starts up but a minutes after i pull away and then come to a stop sign its dies. i just replaced the air filter and sprayed some carb cleaner into the carb and put some fuel additive into the gas tank
Re: '90 Wrangler starts fine but then sputters out and dies [Re: hoki06] #813104 05/19/07 07:57 PM
BigJim Offline
What brown said...idle tubes and fuel filter.. The air cleaner and fuel additives prolly did nothing for ya.
Re: '90 Wrangler starts fine but then sputters out and dies [Re: BigJim] #813105 05/19/07 09:43 PM
hoki06 Offline OP
ok thanks guys
Re: '90 Wrangler starts fine but then sputters out and dies [Re: hoki06] #813106 05/19/07 11:10 PM
BigJim Offline
Hoki What happens is the choke is engaged when it first starts and the mixture is enriched for a short while. Then as the KEY is on and electricity goes to the choke heater the choke slowly opens and the regular lean mixture comes into play. If the idle jets are clogged or the TUBES in the throttle body are stopped up... You get a little less to none at all gasoline in the engine at idle.
This small bit of gasoline is counted for when the hi-speed jets are installed...i.e. the engine COUNTS on the idle amount of gasoline at all speeds! So a carb in your (possibly) condition is running too lean at all speeds.
If that is the problem then it needs to be corrected.
Re: '90 Wrangler starts fine but then sputters out and dies [Re: BigJim] #813107 05/20/07 10:56 PM
hoki06 Offline OP
ok i pulled out the idle tubes and cleaned them out with wire and carb cleaner and put it all back together and it worked fine and didnt stall, idled very steady and right around 800 to 900 RMPs after i adjusted it. that was around 2 today and now its starting to idle very low again and sputter at stop signs but not stalling. what should i do now? change the fuel filter?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6119 MB (Peak: 0.6891 MB) Data Comp: Off Server Time: 2026-06-21 10:52:08 UTC
