Head Gasket #813741 05/23/07 03:11 AM
POLAK50 Offline OP
I was driving down the highway and i lost power..I made it home and checked my oil and it smelt like gasoline. Im figuring thats a blown headgasket. Does anyone know the estimates to get this fixed on a 88' Montero stick?
I dont have a clue how it happened. The Temp has always been fine. Anyone else know how that could happen other then old age?
88' Montero SWB 2.6L 5 speed, Got for free from my folks I couldnt stand the car I first drove just sit there and die.
Re: Head Gasket [Re: POLAK50] #813742 05/23/07 06:14 AM
FrankR Offline
I'd guess it's a blown diaphram in the fuel pump. Replace the pump and change the oil.
Whatever you do, don't keep driving it as is.... not only do you stand a chance of rapidly accelerating engine wear from gasoline dilution in the oil, you also risk a sump explosion and fire.
Frank
Re: Head Gasket [Re: FrankR] #813743 05/23/07 06:29 AM
LRJ4x4 Offline
Ditto, and the fuel pump can be a bear. I suggest you remove the rocker cover so you can see what your doing. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Head Gasket [Re: LRJ4x4] #813744 05/23/07 06:43 AM
CapnCrunch Offline
Be sure to set the engine at #1 TDC on the compression stroke before pulling the pump. It'll come out and go back in a lot easier.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5997 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-06-11 15:13:45 UTC
