Can you adjust a hydraulic clutch??? #814178 05/24/07 06:37 PM
SuperSwamper Offline OP
This might be a dumb question, but I was just wondering if you can adjust it..
It's a 1986 Cherokee chief, if that helps..
Thanks,
Matt
PICTURES OF MY 1986 ISUZU TROOPER PROJECThttp://www.cardomain.com/ride/2524435/1
Re: Can you adjust a hydraulic clutch??? [Re: SuperSwamper] #814179 05/24/07 07:16 PM
G
georgiajeeper Offline
You can try and fabricate a threaded, adjustable pushrod...But I think once you get over a certain length, it compresses the piston too far beyond it's limits...
If you aren't getting the clutch to disengage enough, and the system has been bled properly, you may have to modify your release lever, to get a better angle!
1981 CJ5, 258, T176, D300, D30, AMC20, 30x9.50
Re: Can you adjust a hydraulic clutch??? [Re: SuperSwamper] #814180 05/24/07 07:53 PM
BigJim Offline
The short answer is NO! But, if you are mechanically inclined messing with the push rod or the pedal height might change the timing of an open clutch.
If the clutch is not fully engaging and is slipping...then it is time for a new clutch KIT!
Re: Can you adjust a hydraulic clutch??? [Re: BigJim] #814181 05/24/07 08:47 PM
It's not slipping yet, it just don't engage till you have the pedal 3/4 of the way out..
I like them where they engage right off the floor..
Might just have to get used to it..
thanks,
Matt
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5986 MB (Peak: 0.6541 MB) Data Comp: Off Server Time: 2026-10-21 18:53:46 UTC
