Re: failed emissions [Re: mcpree] #814561 06/02/07 03:08 PM
myyota Offline
Your thermostat is to cold to pass a smog test, put in a 195 degree thermostat.
Re: failed emissions [Re: myyota] #814562 06/03/07 03:11 AM
A
aptech Offline OP
why is the 160 to cold. i thought the NOx was to high due engine temp high in exhaust?
Re: failed emissions [Re: aptech] #814563 06/03/07 08:11 PM
ArbitraryNotion Offline
160 is really low. 180-185 might be ok but stock for emissions would be best.
You have better emmissions at higher temps. Lower temps give you better BOOMs smile
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: failed emissions [Re: aptech] #814564 06/03/07 08:36 PM
4Crawler Offline
Lower coolant temps make the ECU try to warm up the engine, so it is not going to be running in the normal operating mode. NOx is made by high combustion chamber temps, which are really not affected much if any by the coolant temp. To lower NOx, retard timing (I run 0-2 BTDC on mine for smog) and also run premium gas and make sure the EGR is really clean inside.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6079 MB (Peak: 0.6636 MB) Data Comp: Off Server Time: 2026-06-17 03:21:37 UTC
