XJ Air Conditioning
#814602
05/27/07 12:13 AM
I just bought a '99 XJ. All seems OK but when the engine gets up to normal operating temp, the AC shuts off. Does any one know of a sensor or relay that might be the cause of this problem?
Back in the game! '94 YJ 2.5 all stock.
Re: XJ Air Conditioning
[Re: fresnodb]
#814603
05/31/07 02:39 AM
My '98 XJ a/c quits after about 30 minutes because it freezes up. To get it going again, I switch to vent for a few minutes, then I can go back to a/c for a while. It's a little low on refrigerant, but when you refill it it soon leaks back down to the present level. I just haven't had time to fool with it to find out where the leak is.
[Re: fresnodb]
#814604
05/31/07 04:29 AM
Yep! DB give it some refrigerant. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: fresnodb]
#814605
06/05/07 03:43 PM
Thanks Tom & Jim. Evacuated and recharged. Seemed ok for a while, then woulden't cycle back on. Checked pressures, HI & LOW were extreme opposite of what they should be, indicating a stuck expansion valve. This system does not have a replaceable expansion valve. After a while it worked again. Some say theese vehicles had many intermittent electrical problems. The A/C works more than it doesn't work making it difficult to diagnose which I would gladly pay someone to do if it would stay not working! <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: fresnodb]
#814606
06/05/07 03:57 PM
Uh, not replaceable? Then it must be CLEANABLE! But to take the system apart you will need to pull a vacuume on the system before recharging.. I'd advise a trip to the A/C guy. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 2.330s Queries: 15 (0.004s) Memory: 0.6043 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-06 15:27:19 UTCValid HTML 5 and Valid CSS
