Headlamp Washer / Sprayer Retaining Clip Part # ? #815238 05/29/07 08:03 PM
TripleJackInGA Offline OP
Anyone know the part # for the clips that hold the headlamp washer nozzles in place?
I believe these would go on behind the header panel, but never seen an exploded view of it to know for sure.
Mine work, but they flop around a bit.
TripleJack
85 GenI SWB 2.5/5-Speed on 33s
Re: Headlamp Washer / Sprayer Retaining Clip Part # ? [Re: TripleJackInGA] #815239 05/29/07 08:15 PM
Is this for a Gen I, II, or III? Montero or Montero Sport?
Please put your model info into your signature & use it for these kinds of questions... It's too tough to remember everyone's rig from prior questions and it will make everyone's life (including yours) easier. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Headlamp Washer / Sprayer Retaining Clip Part # ? [Re: off-roader] #815240 05/29/07 08:22 PM
DOH!
Sorry about that. It's an 85 GenI SWB 2.5/5-Speed.
TripleJack
Re: Headlamp Washer / Sprayer Retaining Clip Part # ? [Re: TripleJackInGA] #815241 05/29/07 09:28 PM
OK, if nobody comes up with something, I can provide the CAPS p/n's for you when I get home later this evening. You can probably order them from the dealer or get the parts from a salvage yard or perhaps someone here has a spare setup they can send you.
Re: Headlamp Washer / Sprayer Retaining Clip Part # ? [Re: TripleJackInGA] #815242 05/30/07 02:55 AM
cirrus Offline
Try MB141436 (clip) for part number.
good luck
1987 Raider/Silver/5speed/AC/Off road package
356K miles/owned since new/daily driver
Re: Headlamp Washer / Sprayer Retaining Clip Part # ? [Re: cirrus] #815243 05/31/07 12:19 AM
87Raider_TSI Offline
If you don't find that part or your willing to try an alternate way of attaching those headlight washers I'll show how I attached mine.
I dug around in the garage and found a piece of hard rubber hose that has an inner diameter close to the headlight washer. I then cut a piece off about 1/4" in width. I then cut that piece lengthwise and ended up with this:
I dabbed the inside with a little RTV or silicon adhesive and stuck it on.
It's not pretty, but a it's cheap and easy way to keep the headlight washers from flopping around. I did mine about a month ago and they are holding up...and if they ever do fall off it's a 3min repair job.
'87 Raider SWB 2.6T/5 spd - Boxy and boosted.
'88 Conquest TSI - MPI and lots of other mods
Re: Headlamp Washer / Sprayer Retaining Clip Part # ? [Re: TripleJackInGA] #815244 05/31/07 01:20 AM
89montero Offline
one of my clips fell off so i just put some JB weld on the back of one, put the clip on it(to act as a clamp). After about an hour I took the clip off and put it back on the other one. Worked great!
1989 Montero 4dr V6 3.0l
PHP: 7.4.33 Page Time: 1.577s Queries: 15 (0.004s) Memory: 0.6152 MB (Peak: 0.6945 MB) Data Comp: Off Server Time: 2026-06-11 06:47:22 UTC
