over heat question
#815545
05/31/07 12:33 AM
hey all, rebuilt motor fired up first try could not beleive it. but it over heats on me, I removed the thermostate and still over heats, there is no fan shroud do you think that would make a differnce? any ideas? -Rob -florida
Re: over heat question
[Re: Dieselshop]
#815546
05/31/07 01:31 AM
Take the radiator cap off and turn ON the heater; it'll allow the coolant to flow thru the entire system to burp the air out of there. Put the front end on a couple of 2x4 scraps or an incline; air will find its way to the highest point.
Yep, the fan shroud directs the air aft around the engine while it's standing still.
[Re: kewlynx]
#815547
05/31/07 01:39 AM
thanks I still have to fix the blower motor it does not work yet either.
[Re: Dieselshop]
#815548
05/31/07 02:30 AM
You don't need the blower on to burp the air from cooling system. As long as the control valve works and is on "hot" you should be good to go.
[Re: Dieselshop]
#815549
05/31/07 02:34 AM
x 2; the blower has nothing to do with it; the heater control valve for the core is what you're after; put it on 'hot/red'
PHP: 7.4.33 Page Time: 7.020s Queries: 15 (0.004s) Memory: 0.6053 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-06-18 01:06:31 UTCValid HTML 5 and Valid CSS
