MISFIRE engine code p0300 multiple random misfire detected
#815856
05/31/07 10:00 PM
I have had my 2000 3.5L Isuzu since Sept 06 and have had a hard time dealing with my misfire engine code that is apparant 50% of the time during transport. I have a scan gauge and turn the code off daily at start up.
My issues are hard start up that requires depression of the gas pedal during turning the key and after to keep the rpms up or it will die.
Low MPG 13.4 to be exact.
What I have done thus far. Replaced fuel filter New MAF sensor New NKG Iridum plugs Seafoaming EGR cleaning ...
I do have a fuel pressure regulator that just came in the mail.
Will this take care of my symtoms and code? Or what else is needed. Plus there is not a mechanic in the area that wants to work on the VX and the nearest dealer is FAR away.
Please advise.
Thanks,
Re: MISFIRE engine code p0300 multiple random misfire detected
[Re: jharris1385]
#815857
06/01/07 03:01 PM
[Re: jharris1385]
#815858
06/01/07 04:09 PM
The regulator will likely fix the hard start.
Are you sure those are the factory spec plugs, not just what the counter guy told you would work? If not you are asking for trouble. Also when you did the change did you do one plug at a time?. If not you could have misplaced a coil pack. The one by the brake booster is different that the other 5. If you get this one in the wrong place you will have firing problems.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5925 MB (Peak: 0.6459 MB) Data Comp: Off Server Time: 2026-06-12 21:33:42 UTCValid HTML 5 and Valid CSS
