Re: coil spring conversion for YJ [Re: superdawg] #815958 06/04/07 03:25 AM
hoki06 Offline OP
ok so what would be a better setup:
the pro comp 5" coil spring conversion or 4.5" rubicon express heavy duty with revolver shackles
keep in mind im not going to do much rock crawling. ill do some mud running and hopefully get into more trail rides that are a little more challenging but no hardcore rock crawling
Re: coil spring conversion for YJ [Re: hoki06] #815959 06/04/07 05:51 AM
F
Fred Blackstone Offline
Whatever you do, hoki, don't install revolver shakles! Read what Superdawg wrote just above about revolvers.
Re: coil spring conversion for YJ [Re: CoronaJeeper] #815960 06/05/07 04:01 AM
Brown81CJ5 Offline
Ditto what SD said. For all the work/frame butchery that would go into a coil conversion on a YJ, you'd be WAY ahead to trade up to a TJ.
One more point- A panhard bar (or track bar) does nothing to eliminate axle wrap. It locates the axle side-to-side under the Jeep. A lot of guys new to Jeeping are reading this- let's be sure our answers are accurate.
Corona <img src="/forums/images/graemlins/cheers.gif" alt="" />
I wrote nothing that said for fact that a panhard bar helped prevent axle wrap. I simply stated that I thought it did. But the control arms do...am I correct? I own a CJ, not a TJ.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6525 MB) Data Comp: Off Server Time: 2026-06-21 17:52:14 UTC
