Re: Oil change is coming soon
[Re: torquemonster]
#816081
06/08/07 06:10 PM
oil is the most important part of your engine.I just run the Amsoil 15W40 and man does my truck love it. OK, I faced with certain difficulties to find syn oil, but finally found the place to go. Anybody wants to join me in BC area? Please send PM to get the order running. Cheers, <img src="/forums/images/graemlins/cheers.gif" alt="" />
Fight for Right to drive from Right! www.ivoac.caStay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
[Re: Pajerist]
#816082
06/09/07 02:31 AM
What type how much ect...
1991 MITSUBISHI PAJERO EXCEED
[Re: DonM]
#816083
06/10/07 06:17 AM
What type how much ect... well, this is <Amsoil>, synthetic oil brand recommended by torquemonster. The dealer is in Toronto, so to keep transportation cost low I 'd like to get 4-5 mate together. You can see specification here: http://www.sinwal.com/?gclid=CObRirHl0IwCFQE9hgodlwakpwStay in touch, <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Pajerist]
#816084
06/10/07 07:12 AM
When my Pajero ends up coming in, I'd like to run a bypass filter system on it.
Have any of you used or are using a bypass filter such as the Amsoil one ? The BMK-12 is the one I was thinking of using as it's suited for small engines and has a dual filter system.
Anyone ?
Thanks, Jesse
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on 89 Montero - Project 92 Pajero Exceed - Gone to a good home 92 Delica Chamonix - Gone to a good home
[Re: Pajerist]
#816085
06/11/07 03:10 AM
You should easily be able to get Amsoil locally...Napa sells it, canadain tire sells it, its everywhere. there will be a Amsoil distributor that supplies all the shops with them that you can get ahold of that would sell it for cheaper.
[Re: torquemonster]
#816086
06/11/07 03:53 AM
You should easily be able to get Amsoil locally...Napa sells it, canadain tire sells it There are nothing in our Canadian Tire, Mr.Lub etc. (I checked with three local stores) as for Napa, I'll call them tomorrow... BTW, what kind will better fit our diesels? Thanks, <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Pajerist]
#816087
06/11/07 06:36 AM
by what kind do you mean what weight??? don't run any lighter than a 15W40. Winter time would obviously be a different story. last winter I ran 0W40 Rotella, but I am not with Rotella. I will run a 5W40 Amsoil this winter.
[Re: torquemonster]
#816088
06/11/07 06:37 PM
don't run any lighter than a 15W40 OK, two questions: 1.Why so? 2.What kind of oil do you use Synthetic Heavy-Duty Diesel & Marine Motor Oil SAE15W-40 (AME) OR Synthetic Blend 15W-40 Heavy Duty Motor Oil (PCO)? Thanks, <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Pajerist]
#816089
06/11/07 06:40 PM
I use diesel oil...it has WAY more detergents in it to clean all the crap out. I sometimes use 15W40 diesel oil in my gas car too. it sure likes it.
[Re: torquemonster]
#816090
06/13/07 03:50 PM
I saw in the owner's manual 10W30, I guess it is not big different, so why do you use 15W40? Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
