New Suspension #816546 06/04/07 04:29 AM
thefarky Offline OP
The suspension on my Pickup(stock) is starting to sag and I can really feel it on speed bumps and dips. It feels like my rear end is getting airborn.
Any good suggestions on suspension kits? Also, would it be worth it to look into a mild lift while I am at it?
1995 Toyota Pickup, SR5 3.0V6, 31X10.50 Mud Tracs
Re: New Suspension [Re: thefarky] #816547 06/04/07 06:50 PM
cktoy Offline
coils over the rear axel do great for the money.mount them over the bump stops gets out the sag and adds about 1.5-2".gear installs site has good pics.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: New Suspension [Re: thefarky] #816548 06/04/07 11:48 PM
Snowtoy Offline
adding another main leaf will also give you lift and can be done rather cheaply, usually under $30. I like to use the first leaf down from the main leaf from 56" Chevy spring pack, and insert it between the Toyota main and the second leaf. To do this you may also need 2 new center spring bolts if your oem ones aren't long enough to accomodate the additional spring.
Re: New Suspension [Re: Snowtoy] #816549 06/05/07 12:06 AM
thefarky Offline OP
Thanks, but also what about the front suspension?
Re: New Suspension [Re: thefarky] #816550 06/05/07 02:39 AM
4Crawler Offline
For a little height, crank up the torsion bars or install some ball joint spacers:
- http://www.4crawler.com/4x4/ForSale/BallJointSpacer.shtml
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6055 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-06-17 12:11:26 UTC
