Help! Timing Belt replacement. #816862 06/06/07 12:40 AM
9
98and94Amigo4x4s Offline OP
'98 Amigo 2.2L - There are supposed to be some marks on the water pump to correctly align it when replacing the timing belt. We cannot find any - can anyone tell us where to look? (Or why you would "align" the water pump?) Also, the tensioner for the timing belt does NOT resemble the diagram in either of two tech manuals. There is supposed to be a notched area for aligning - we have a scale - sort of - there is a pointer in front of a white strip, the white strip shows 65 (degrees sign) C. Anyone have a clue? Thanks!
Another question! Has anyone done the timing belt in a 1999? Our belt appears to self-adjust (the tensioning pulley adjusts itself after you have attempted to set it per 1998 tech instructions.) It was sold new in late November of 1998 and so we are wondering if it is one of those 1998 1/2 or 1999 sold as a 1998. I would sure appreciate any feedback.
Thanks again!
Re: Help! Timing Belt replacement. [Re: 98and94Amigo4x4s] #816863 06/14/07 12:02 AM
mtboulder Offline
I'm not familar with the 2.6L but agree that it does not make sense why you would have to line up the water pump.
I've done the timing belt on a 1998 and it is self adjusting. The tension pulley has a tensioner that you should replace. The new one has a pin it the shaft and once it's installed you pull the pin and it provides the correct tension. You should see a small hole in the steel shaft on the existing tensioner where the original pin was located prior to being pulled out.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5888 MB (Peak: 0.6374 MB) Data Comp: Off Server Time: 2026-11-15 12:20:37 UTC
