Re: Garage Heat [Re: jasonmt] #817203 06/11/07 01:42 AM
kewlynx Offline
We had a double stacker at home for our shop.
Yeah, if the drum steel is that lighter guage stuff, get some firebrick or gravel to put a layer in the bottom, or you'll burn thru that beechnut. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />
The stuff for the stack should be metalbestos, and I also recommend a strap bracket to the wall to keep it plumb. We use that hardware up here for earthquakes. I like Ted's suggestion about the concrete block around it. Good thermal mass.
You might want to give your fire marshall a call to see if there is any code for that thing. Code here is a MINIMUM distance of 18" from the wall and 4" off the floor. I also recommend a reflective barrier of some sort; I've got some AL diamondplate for that job; it's offset from the wall by 4" Good place to dry yer gloves! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Also if your home insurance finds out you have it, your rates might go up. <img src="/forums/images/graemlins/shame.gif" alt="" />
Do a little homework for your install. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Garage Heat [Re: kewlynx] #817204 06/12/07 07:17 AM
stony-man Offline OP
So let me get this right. FOR IN MY HOUSE, I could build a block wall, insulated with Sand, around the wood burner. How would I tie into my current duct work so that I can utilize the fan on my furnace to push heat upward. I really want to be able to get off the Gas Company teet this winter...it's unbelievabley expensive. In the garage, I'll just build around the barrel stove, filing the cores with sand. I doubt I'll need more than just the ambient heat, but if I do, I figured I could put a couple vent fans in to push heat around.
Re: Garage Heat [Re: stony-man] #817205 06/12/07 07:24 AM
kewlynx Offline
I thought this BARREL STOVE was going to heat your garage??? NOT your house??
On your house vents, do some inspecting to see if any of the ductwork is loose/leaking air. They've got some AL tape for sealing that stuff up.
Got a basement I take it? Can't give you any help for your muddled description or what it is you actually want to do what the barrel stove. Fire marshall would frown on that thing being in the basement with a gas furnace.
Re: Garage Heat [Re: kewlynx] #817206 06/12/07 07:26 AM
52degrees Offline
What about an outside wood furnace with a water circulator?
KG6VNX
Re: Garage Heat [Re: 52degrees] #817207 06/12/07 07:36 AM
kewlynx Offline
IF Stoney wants to do this on the cheap, that won't happen soon.
Gotta get the kids a little bigger to help get in the wood too. Those are actually pretty popular up in the Interior.
In Spokane WA where my Dad's family lives, they banned wood burning stoves in the county several years back.
Sounds like he's got forced air heat. If he had a boiler in place, IIRC, you can plumb them in. So there's a plumbing job to be had on top of it.
My grandparents' place had a forced air wood furnace. We'd go thru about 12 cords/year for about 2400 SF in the Idaho panhandle. <img src="/forums/images/graemlins/nana.gif" alt="" />
I think that much wood, and there goes Stoney's kids' swing set!
Stoney, scope these; out of MN.
http://www.yukon-eagle.com/index.html
Re: Garage Heat [Re: kewlynx] #817208 06/12/07 02:49 PM
RichinROA Offline
You could use the official Army Corp of Engineers campsite fireplace:
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: Garage Heat [Re: RichinROA] #817209 06/14/07 04:07 AM
kewlynx Offline
I've got 3 of 'em. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Garage Heat [Re: kewlynx] #817210 06/16/07 05:23 AM
Macka Offline
my camp has one from a duece and a half.
always working
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6333 MB (Peak: 0.7302 MB) Data Comp: Off Server Time: 2026-07-13 15:49:39 UTC
