Black Smoke And Fuel Smell Exhaust #817303 06/07/07 08:27 PM
TrooperMark Offline OP
Ok guys '95 Trooper 3.2 Sohc 195,000 miles
Its obvious that I have a fuel mixture problem. I'm not getting any check engine lights or services codes. So where do you think I start. EGR, MAF, PCV, Cat, bad injector, etc...
Of course I'm trying not to replace all components so which do you think is the most likely.
Thanks Mark
1995 Trooper LS (OME Coils & 2" spacer, Rancho 9000, Nitto Terra Grappler 34", K&N, ARB Snorkel, Calmini Rear Bumper) In garage (9000 winch, custom S. America winch bumper, Delta Cams, Tera-Low 3.07)
Re: Black Smoke And Fuel Smell Exhaust [Re: TrooperMark] #817304 06/08/07 01:01 AM
JLEMOND Offline
START WITH THE O2 SENSOR, IT IS PROBABLY SHORTED INTERNALLY, UNPLUGGED IT WILL GO INTO A FAIL SAFE MODE AND PROB, TURN THE CEL ON, SEE IF THAT DOESNT CLEAR UP THE SMOKE JERRY
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5874 MB (Peak: 0.6355 MB) Data Comp: Off Server Time: 2026-07-15 00:04:44 UTC
