pulls to right when braking #817754 06/09/07 11:13 PM
playinmud Offline OP
i pulled the front pads off and put brake quiet on them because they were squeaking like crazy every time id brake, the squeaking went away but now my jeep pulls to the right when braking normally and hard, it never did this before, how do i fix this?
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: pulls to right when braking [Re: playinmud] #817755 06/09/07 11:57 PM
hlhneast Offline
I dunno for sure but the squeaking you refer to may have been the little tangs that some manufacturers use to indicate brake wear. You should also be able to hear them as you drive as a light singing from the wheels. If this is the case, you may need to replace the pads. Any number of reasons will make your jeep pull. One caliper may be sticking somehow. On older CJ's there are slide clips that require a small amount of "caliper grease", the technical name escapes me now, on these clips and the bracket and caliper surfaces for smooth operation. Since you just pulled the pads and messed with the calipers, I would think you may have a sticky one if you dont have the slide clips. Check a Factory Service Manual for lubrication points and use the proper grease. You can get small packs of the grease at the parts house that are enough to do all the brakes. Dont let this grease contact any part of the pads or anywhere but indicated by the manual. Hope this helps. Good luck. <img src="/forums/images/graemlins/kewl.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Re: pulls to right when braking [Re: hlhneast] #817756 06/10/07 12:34 AM
hlhneast, the pads are brand new the previous owner redid them in november and about a month after i got it they started sqeaking, they're duralast semi metalic pads, i didnt get any grease on the pad and i used the caliper grease on the clips and brackets, i drove it around a couple blocks again and it didnt pull as bad as the first time, and the sqeaks came back, would i be better off using that spray on stuff that dries to like a tacky gel? the stuff i used is called caliper grease, its made by Gunk and it says it you can use it to slience the pads, didnt seem to work
Re: pulls to right when braking [Re: playinmud] #817757 06/10/07 02:16 AM
BigJim Offline
Why mess with em? Just go get a new set and make sure there is a "no squeak" pad in the box before paying for it.
Re: pulls to right when braking [Re: BigJim] #817758 06/10/07 04:11 AM
BobRowe Offline
Makes sense to me! A set of pads for the front costs, what, about $20 to $25? and takes about 10 minutes per wheel to change. In the process of changing the pads, you'll also lube the proper places, and put the anti-squeal thingy in place.
Re: pulls to right when braking [Re: BobRowe] #817759 06/10/07 05:47 AM
they're brand new, they were replaced in november, tomarrow im gonna try a different brake quiet, but im more worried about it pulling to the right now because now i have to turn the wheel like a quarter turn the left to keep it going straight when stopping
Re: pulls to right when braking [Re: playinmud] #817760 06/10/07 07:36 AM
BigJim Offline
And I thought I was tight! That ain't the brakes squeaking...it's YOU~
Re: pulls to right when braking [Re: BigJim] #817761 06/10/07 03:10 PM
haha funny one BJ, could it be something i the pads themselves that are making it sqeak? they werent glazed or cracking or anything
Re: pulls to right when braking [Re: playinmud] #817762 06/10/07 06:22 PM
BigJim Offline
Yeah, the guy you bought it from prolly didn't put the anti-squeaks behind the pads! You most likely CANNOT get the squeak out of the brakes without installing some with the proper anti-squeak pads that should come with them.
Re: pulls to right when braking [Re: BigJim] #817763 06/11/07 03:26 AM
yea there was none on there, it doesnt squeak near as much but it still does which drives me nuts, but how do i get it to stop pulling to the right when braking?
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6356 MB (Peak: 0.7594 MB) Data Comp: Off Server Time: 2026-06-16 18:30:08 UTC
