gear ratios?
#817964
06/11/07 03:49 AM
how do i find out my stock gear ratios?
shane,88 toyota 4runner, v6, 5spd, 31x10.5x15 pro comp mudders, pacer wheels, flowmaster exaust, cold air intake.
Re: gear ratios?
[Re: toyotateen88]
#817965
06/11/07 03:50 AM
Data plate on your door jamb or the engine firewall, depending on the year.
Go to our Toyota FAQ link above for VIN/Specs to decode.
Re: gear ratios?
[Re: kewlynx]
#817966
06/11/07 03:53 AM
Re: gear ratios?
[Re: 4Crawler]
#817968
06/11/07 02:12 PM
ok so i looked everything up and i come up with 8.0"rear with 4.10 gears and 2 pinions does that sound right.it sounds kinda low to me...for stock.
Re: gear ratios?
[Re: toyotateen88]
#817969
06/11/07 02:19 PM
4.10 is typical gearing for a manual transmission and 28" tires. Should be 4-pinion with the V6, but 2 will work as well. Trucks with 5-speeds and 31" tires came with 4.56 gears from the factory (that was only offered in the early 90's models).
Re: gear ratios?
[Re: 4Crawler]
#817970
06/12/07 11:09 AM
I don't believe they offered 31s until model year '89 on the trucks and '90 on the 4runners. As for having a 2 pinion on a V-6 truck, that was not very common, but being as you have a very early V-6 truck, that might explain it. The 4 pinion diff was first offered on the turbo 22RT-E models, but may not have been commonly offered on the V-6 models until '89 and later.
