Ideal RPM Limit? #817979 06/11/07 06:02 AM
OFFRD88 Offline OP
I've searched through lots of posts, and primarly saw discussion of maximum RPM depending on mods, etc-. I've seen the stock redline is around 5750, with various rev limits programmed into the ECU in later years.
I have an MSD 6AL, and need to get a "pill" for it. My setup is a 22RTE short block with a 22RE head and mild cam (not sure exact specs). I'm not looking to have a screaming drag racer, I just want a nice safe setting for offroad use (sand and other instances where over reving may occur).
Would 5800 be safe? Should I go lower?
Thanks in advance,
Dave A.
88 P/U lots of mods
95 4Runner on 33's with a Detroit
Couple of mountain bike's rolling on 26's.
Re: Ideal RPM Limit? [Re: OFFRD88] #817980 06/11/07 03:50 PM
G
Greg_Canada Offline
EB would know best, but with ARP bolts everywhere, and better valvesprings you could push 6500 RPM...
89 4Runner
Re: Ideal RPM Limit? [Re: OFFRD88] #817981 06/11/07 10:19 PM
dcg9381 Offline
Safe seems to be a function of when the valves begin to float for OHV motors. When do stock valves begin to float? I don't know for sure. I've hit 5500 on a stock motor accidentially. With improved valve train, you can go higher...
The question is: Why would you want to go higher than about 5500? Stock torque has fallen off hard after 4500 or so. Unless you're pushing more boost or actually get power in that upper range, just keep that RPM limit to a sane level. Running a "stock" motor to 6k will result in a higher ET than shifting it earlier... No reason to spin it that high.
22REturbo.net
1988 4Runner
Re: Ideal RPM Limit? [Re: OFFRD88] #817982 06/12/07 03:05 AM
OFFRD88 Offline OP
I'm not really looking to wrap it out, I just want to set the rev limit at a point where I don't have to cringe if I hit it, but I also don't want to set it too low. Looks like maybe 5500 is a nice safe place to limit it? I'm not talking regular shift point, I'm talking absolute maximum RPM.
Dave A.
88 P/U lots of mods
Re: Ideal RPM Limit? [Re: OFFRD88] #817983 06/13/07 04:08 PM
G
Greg_Canada Offline
stock redline is 5750... so 5500 would be a safe redline for sure...
89 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6049 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-06-21 19:09:22 UTC
