Front End All Locked Up #818040 06/11/07 06:44 PM
PitterCol Offline OP
Hope you guys don?t mind my asking this here even though it pertains to a non Mitsu product. It?s just that this is the most active and helpful forum and my other car which I?ve posted about here is a 2007 Montero. Can I use that as an excuse? Anyway hereÆs the sequence of events. I drove up the steep, unpaved entrance to my house, about a quarter mile, in four wheel drive in my 4x4 Mazda pickup. At the top of the drive I shifted out of FWD and pressed the dash switch which electrically disengages the front hubs. Then I pulled forward into my dry cement parking area and reversed making a ninety degree turn and parked. The next day I started up the truck, shifted into first, started to let out the clutch and it wouldn?t move. At first I thought the parking brake had frozen for some reason and gave it some gas to break free. Then I realized the rear wheels where spinning in place and that it was the front end that wouldn?t turn. At this point I should have jacked the front end up so at least one wheel was free in the air but I didn?t. Instead I shifted the transfer into 4 Low and started to ease out the clutch. There was a loud clunk and it broke free. I shifted back into 2 High and went on my way. I later shifted into 4 High on some steep loose sections and the 4x4 system seemed to work as normal nor were there any strange mechanical sounds. So what happened? How could the front end have locked up solid or was it from the transfer case forward? All I can figure is the front hubs and 4x4 didn?t disenge during the short distance I was in reverse and the short ninety degree turn somehow bound up the transfer case. Any ideas? Also I promise not to ask anymore non-Mitsu questions here.
Re: Front End All Locked Up [Re: PitterCol] #818041 06/11/07 08:18 PM
allsierra123 Offline
Usually to disengage you need to reverse atleast 3 meters.
91 Mitsu Montero RS LWB PENDING
88 Cherokee Lifted and modded heavily. FOR SALE
91 vanagon syncro 1.9 TD SOLD
04 Suzuki Aerio Commuter SOLD
90 mits mighty max,v6 SOLD
94 Mits Diamante LS. Stock. TOTALED
71 VW Baja Bug SOLD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5869 MB (Peak: 0.6363 MB) Data Comp: Off Server Time: 2026-07-11 00:42:24 UTC
