SPAL fan controller on my taurus fan is not holding up....
#818257
06/12/07 07:01 AM
So....I've got the SPAL FAN-PWN controller on my Taurus fan...for my 3.4L....and it's melting fuses. It just doesn't put out enough AMPS to handle the high power (2nd speed) of the Taurus fan. I called SPAL and asked them and they said 'yeah...the taurus fan draws too many amps at on the high speed for their controller'
Anyone got any ideas or suggestions for a cooling fan controller?
The Taurus Fan draws around 35 AMP's (the SPAL controller is only good to 30 amps) at high speed and something like 70 AMP on start up. I'd like something that handles both speeds of the fan...But, at this point I'd take anything that is reliable and turns the darn thing on without eating fuses.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: SPAL fan controller on my taurus fan is not holding up....
[Re: CORunner93]
#818258
06/12/07 01:54 PM
What controls the fan on the Taurus? Can it be adapted to work on your rig?
"Serenity through Sobriety"
[Re: CORunner93]
#818259
06/12/07 03:19 PM
Toyota Moderator
What if you used the grey wire to operate a relay? Their documentation says it is normally used to trigger a relay for a secondary fan when controller reaches its "high" setting. You could use it to drive a relay that bypasses the controller when its in its high mode, so the controller doesn't have to have to carry the "high" mode current.
And the other (more obvious) thing- what happens if you just put in a bigger fuse?
Oh, and another possible option- use the SPAL's normal output to control the low speed wire of the fan, and then use the grey wire to turn on the high speed when in "high" mode...
[Re: Robinhood150]
#818261
06/12/07 03:33 PM
Toyota Moderator
Yes, pulse width mod. But its grey wire output is not PWM, it is only off/on depending on whether its on "high" mode or not.
[Re: ErikB]
#818262
06/12/07 11:34 PM
What you need to do is have the controler wired upto a second relay that will take the amps of the fan. Basicly a relay switching a relay I used a 30 amp for the low speed and a 70 for the high speed. That way the controler is protected.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: ErikB]
#818263
06/13/07 03:59 AM
Then in that case yeah, run big relay with the controller. What I did with my taurus fan was run two 30A relays in parallel for the high setting.
[Re: CORunner93]
#818264
06/13/07 04:52 AM
Ahhh....I got it!!
After a bunch more research and another call to the SPAL tech support line, I got a wiring diagram which does exactly what I want it to do......it controls both the low speed and high speed powers of the fan! And, you were all about right...a couple of relays, controlled by the grey wire to run high amp power directly to the fan (without having the high amp power going through the controller).
It modulates the low speed fan power through the fan ground (-) until the temps get to within 10-degrees of the "max" setting, that I've programmed into the SPAL controller, then it kicks in the high speed on the fan, at 100% power, until the temps drop down to 10-degrees below the "max" temp setting. When the temps get down below that threshhold, the controller goes back to modulating the power to the low speed wire on the fan. It's perfect, exactly what I wanted it to do in the first place.
I kept getting hints from here and Pirate that there was a solution for this issue...using the SPAL controller....but it took a call to the tech support line to get the wiring diagram.
It's funny, I started talking about my problem and as soon as I mentioned I had a "Taurus fan" the guy knew exactly what I was trying to do and exactly what I needed....he even e-mailed me the wiring diagram. I must have spent 3 hours searching bulletin boards for a wiring diagram or even just a description of how to wire it all up...and got nothing. All the posts mentioned that a relay was needed (which I knew)....but all were focuses on controlling only one speed of the 2 speed Taurus fan....and even with those you could either modulate the low power or only have 100% high power.
The tech guy also mentioned a few interesting things about the Taurus fan. The thing draws around 100-amps on start-up of the high power. But, the way their wiring diagram is set up, the fan is already spinning when the high spped kicks in, so you only have to deal with about 40 amps. All the posts I read said a 70 amp relay and fuse were needed to handle the high power start up. the Tech support guy told me that if you go that route you also need to buy a fire extinguisher for the resulting fire.
I'm having a few computer problems at the moment, so I can't post the PDF. But if anyone is interested, send me a PM and I'll forward the PDF of the wiring diagram.
Thanks for the help, as usually
[Re: CORunner93]
#818265
06/14/07 05:43 AM
Hey man. Here's the diagram you refered to above: Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato http://www.scaldeddog.com
[Re: ScaldedDog]
#818266
06/15/07 01:21 AM
Yeah...thats' the one....thanks
