Cylinder head application/ exchange
#818446
06/13/07 01:29 AM
Hello folks. Glad to be a member of the board. Having just acquired my first Kia, I have a question or two regarding cylinder head application and/or exchange. The vehicle is a 1995 Sportage, 5 speed, 4x4, 2.0 litre, SOHC. After examination, it appears the cylinder head is cracked in the area of the #1 cylinder (pushes coolant out of the radiator when trying to start the truck). Is it possible to swap the cylinder head for a DOHC head, or is that not possible. Assuming that not being a possibility, does anyone on the board have a useable SOHC cylinder head for this truck? Any other cylinder heads interchangeable with the SOHC? Thanks in advance, David.
Re: Cylinder head application/ exchange
[Re: edselsouth1]
#818447
06/13/07 12:58 PM
You can not replace the SOHC with the DOHC head many things are different. You may have a bad head gasket causing this problem.
2009 Sorento LX, 4x4, V6, Auto, Red
[Re: Airdale73013]
#818448
06/13/07 08:41 PM
Kia Moderator Emeritus
I would have to agree with Airdale that it cannot easily be done. I believe some of the castings in the block on the front are different. Also the water pump uses a different timing gear.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Axe Man]
#818449
06/14/07 02:41 AM
Airdale, AxeMan, Thanks for the information. It's possible that the problem may be only a head gasket. I have not removed the head as of yet, just trying to line up a head in the event I may need one. Anyone with a useable SOHC , 2.0 head, let me know. Thanks, David
[Re: edselsouth1]
#818450
06/14/07 12:22 PM
http://www.cylinder-heads.com/ have rebuilt heads their heads are complete with cams they should have a sohc head the dohc head is $375 plus $20 shipping sohc should be the same price. good luck check to see if a good headgasket will be the fix but if the head is cracked it will need to replaced I think your head even if cracked can be returned to cylinder-head they are master rebuilders
[Re: bombardj1]
#818451
06/16/07 05:04 AM
bombardj1, Thanks for that cylinder head info. I'll check with them on the availability if I need a head. Thanks, David
