Spacer
#819621
06/18/07 05:30 AM
Good day all
When doing a ball joint flip, when is the addition of a spacer necessary? I am considering going the conservative route and opt for a 2" suspension lift, and a flip on the front end. Should a spacer be considered and how thick should the spacer be?
Happy travels
'99 Isuzu Frontier (Rodeo) Intercooled 280DT LX
Re: Spacer
[Re: Egelwolf]
#819622
06/18/07 05:51 AM
Nothing bigger than 1/4 inch for the spacer.
Re: Spacer
[Re: Egelwolf]
#819623
06/18/07 11:21 AM
Isuzu Moderator
With 2" of lift, a spacer shouldn't be necessary. When Joe was selling them, he marketed the spacers toward people with 3+" of lift.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
Re: Spacer
[Re: strawmyers]
#819624
06/21/07 06:23 AM
Any reason why it shouldn't / can't be done with a 2" lift?
Is there a template for the spacer available somewhere?
Re: Spacer
[Re: Egelwolf]
#819625
06/21/07 11:49 AM
What the spacer will gain you in lift is negligible. The spacer is there to help realign the suspension so that it can be brought within specs. With 2 or less inches of lift, this isn't a problem. There is plenty of leeway for the alignment to be brought to specs. But with 3+" of lift, it becomes increasingly more difficult to get it to within specs. That's why you put the spacer in there ; it helps realign things so that it can be properly aligned.
Re: Spacer
[Re: Richard Saylor]
#819626
06/21/07 11:51 AM
Forgot to add ...
The problem with adding a spacer with such minimal lift is that it can also through your alignment out so bad that it can't be brought within the specs. It's just the opposite of what you'd get with too much lift without the spacer. Hope that made sense.
Re: Spacer
#819627
06/21/07 02:41 PM
Thank you for clearing that up. Much appreciated.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6188 MB (Peak: 0.6936 MB) Data Comp: Off Server Time: 2026-06-05 17:35:39 UTCValid HTML 5 and Valid CSS
