Page 1 of 4 1 2 3 4
SPENDIN SOME MONEY........ #819639 06/18/07 06:23 AM
A
Adskia Offline OP
hi everyone....just seeing what u think is a good diff combo to do a live axle conversion .....want matchin diffs front and rear of the same make(toyota,nissan or dana)and has anyone turboed a kia engine......hehe....got my eye on a nice turbo....only want a low boost kit to spool up quick to build up torque(even a supercharger i would consider as well)......what u think guys........ <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
THE POWER TO SUPRISE.
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819640 06/18/07 09:10 AM
hvac1000 Offline
I do not have to courage to put a turbo on my Sporty. I am happy when it runs well. If you look at some of the pics here you will see some amazing suspension work being done on the rocks ETC. The Sporty also has a pretty mean low gear.
Re: SPENDIN SOME MONEY........ [Re: hvac1000] #819641 06/18/07 09:18 AM
A
Adskia Offline OP
not low enough for me with 31s.....tends to run away down slow climbs......seriously thinking about turbo or superchargeing it......what u think guys.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819642 06/18/07 11:01 AM
O
oul053 Offline
turbo charge it!!! i have thought bout turbo my thning but i have 1 turbo car already and i know how hard i drive it so i dunno if the kia could take that sort of punishment. the hardest part would be making a manifold and seeing if the standard computer will be able to retard the timing enough so it doesnt ping itself to death, otherwise u will need an aftermarket ecu or piggyback $$.
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: SPENDIN SOME MONEY........ [Re: oul053] #819643 06/18/07 11:10 AM
A
Adskia Offline OP
i have just finished payin me credit card off so i want to use it.......hehehe.......was thiking of a piggy back microtech to get rid of the airflow meter.....
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819644 06/18/07 11:30 AM
A
Adskia Offline OP
have used a microtech before(diahatsu charade with 1.0lt turbo injected was good for 160kw at the wheels)know what they are like.....and i might have a turbo for it...... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819645 06/19/07 07:54 AM
O
oul053 Offline
do it! take it off the road for a few wks and do it <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: SPENDIN SOME MONEY........ [Re: oul053] #819646 06/20/07 12:27 AM
DEFBOY35 Offline
turbo's generally dont make enough increase in the low end of the power band to make any real difference for wheelin unless all you do is tear through the mud at high rps!
a supercharger makes more sense for our applications as it is instant power across the entire power band. and if you are not planning on high boost a supercharger will most likely be a better option.
downsides are it would be much easier to do all the fabwork for the turbo.
either way you will be looking at a new injector set up, most likely ignition and definately some sort of ecm upgrades.
not sure of how much bosst, YET!!!!, that the engine will handle with stock internals though.
this is something that is definately on my to do list as I would rather keep it a kia for now and not do an engine swap. although, it may end up being a easier adventure with much better results to do the swap.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: SPENDIN SOME MONEY........ [Re: DEFBOY35] #819647 06/20/07 07:42 AM
A
Adskia Offline OP
thats theway im thinkin at the moment .....keep the heart of it kia....already have bigger injectors to go in am looking at a turbo on the weekend......have to intercool it as the compression is reasonably high....only want about 6-8 psi thru it ....
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819648 06/20/07 08:04 AM
O
oul053 Offline
just look for a small turbo so it spools up down really low but has nothing up high, maybe a turbo from a gtr skyline as they r a twin turbo they r kinda small...
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6388 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-11-14 22:51:24 UTC
