Page 4 of 4 1 2 3 4
Re: SPENDIN SOME MONEY........ [Re: flyboy367] #819669 07/09/07 12:17 AM
A
Adskia Offline OP
have the turbo guys.......its a hybrid garret t03 with a t25 turbine and wheel......went to a turbo specialist and they have told me that it will start to make boost at 1800rpm but wont be any good after 6000rpm.....sp thats good then......gunna start to make the manifold soon.....
THE POWER TO SUPRISE.
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819670 07/09/07 12:59 AM
Everet Offline
They said it won't be any good after 6000 rpm...would it be worse than running NA?? or will the boost just fall off and you wouldn't make any more HP? Could you ask your sources what might work from 1300 to say 5000 or so? I run a lot more at that range than I do 5500+ rpm. Usually don't take her over 4500.
Thanks, Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819671 07/09/07 03:10 AM
flyboy367 Offline
sounds good. i have a tube header layin in my garage still i belive. if you want it pm we we can work out the details. at least you would have the proper flanges and the intake ports are already ported out and welded from the rear.
sounds like a good turbo. i just really started working with them 2 years ago so there is a lot i dont know about them. my wife cant stand that i can read the history of the sbc 302 300 pages but i cant even get into a regular novel lol
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: SPENDIN SOME MONEY........ [Re: flyboy367] #819672 07/09/07 08:56 AM
O
oul053 Offline
sounds cool adam. i will c how ur turns out and what problems u have then i will look at doing the same, i got the 4 runner 4 sale now, so i can start to do some more work on my kia. i think i might use the turbo from a gt forrester they r pretty small and i got 1 lying around here anyway.
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: SPENDIN SOME MONEY........ [Re: oul053] #819673 07/09/07 09:25 AM
A
Adskia Offline OP
have heard that the subarus turbo is a good match for the kia engine............am interested about the tube header mate......pm me.....
Re: SPENDIN SOME MONEY........ [Re: flyboy367] #819674 07/09/07 01:36 PM
Hydra747 Offline
Hey Don,
What did you ever do with your exhaust from the Sportage?
What were the measurements again?????
Re: SPENDIN SOME MONEY........ [Re: Hydra747] #819675 07/09/07 08:59 PM
flyboy367 Offline
still got it i think. ill have to check the garage. busted my shoulder at work so i have tommorrow off. ill try to check.
Re: SPENDIN SOME MONEY........ [Re: flyboy367] #819676 07/10/07 02:48 PM
Hydra747 Offline
I ask for the measurements cause I remember ther was an issue with a decrease in torque at lower RPM's???
Was wondering.....
Thanks------ Mike
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6289 MB (Peak: 0.7118 MB) Data Comp: Off Server Time: 2026-06-22 10:10:13 UTC
