Page 3 of 4 1 2 3 4
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: hazy_daze] #819761 06/20/07 12:12 AM
So this works on the Gen2 as well? I'd only done it on Joni the Gen1 3.0. Those belts tracked true for about 15k miles, IIRC, before I parked her. They also kept the nice sharp edge on both sides, and didn't fray at the side flange. I also note that 'cause the running surface is convex with a curvature who's radius is about equal to the radius of the pulley, so any mild bearing wear and resulting tilt of the pulley is compensated for, and the belt rides the same as it did new, which it likes a lot.
NAPA can order direct from the goodyear catalog, or at least my "used to be a NAPA" good old local parts house could. I think I paid about 16 or so, too. Goodyear made an elegant pulley. Wonder what asian mfr they buy it from. Tell me it ain't so....
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: fasteddy] #819762 06/20/07 03:08 AM
stony-man Offline OP
I was hesitant to go that route with my GenII, but if someone can confirm that it worked on a GenII, I'll give it a shot. Otherwise I'll probably just wait and order from mitsubishiparts.net since my new mechanic is soooo cheap, I might be able to swing those. <img src="/forums/images/graemlins/smile.gif" alt="" /> Although seeing as how his las few posts were about 2 of his rigs blowing up, I'm a little nervous. <img src="/forums/images/graemlins/confused.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: stony-man] #819763 06/20/07 03:18 AM
hazy_daze Offline
Is the belt routing a GenII 3.0 different from the GenI? If it's not, then I don't see any reason why it won't work.
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: hazy_daze] #819764 06/20/07 03:19 AM
It LOOKS the same from the pictures I've seen posted here, but I'm MR (mechanically retarded), so my opinion should be ignored.
I'm going to go ahead and pick up a pair of either the Napa or Goodyear pulleys tomorrow. Cmonty, thanks for the offer to send me yours! So I'm going to be the first guy to try these on a GenII? Coooool. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: stony-man] #819765 06/20/07 12:49 PM
Steve Nichols Offline
Fitted them on my Shogun (MkII) back in Jan/Feb, not too sure as I've had a few tins since <img src="/forums/images/graemlins/cheers.gif" alt="" />
Anyway, have not had a problem with them, tho' the stealer looked at them long & hard when I called in to get the codes read (O2 sensor failed as a result of some bad fuel)
Go for it, they are still cheeper than OEM even with shipping to the UK & a 6pack to a friend for his trouble.
SteveN <img src="/forums/images/graemlins/wink.gif" alt="" />
Shogun (Pajero/Montero) 3.0L V6 12valve LWB Auto 1993
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: Steve Nichols] #819766 06/20/07 02:18 PM
sparkem Offline
My 91 gen1 and 93gen2s are the same, both 3.0s. Get some cheap ones. I had a Mitsu one and a cheap one on my flooded raider. The cheap one still turns (sealed bearings), Mitsu one is rusted shut (newer style I thought were sealed).
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: sparkem] #819767 06/21/07 02:05 AM
hazy_daze Offline
While at the movies a little while ago, a GenII was parked next to me when I went to leave. The driver was in it, idling. I asked if I could look under his hood. He looked at me kinda funny and then we got to talking and I told him why I wanted to look... yada yada. Anyway, the belt routing on his was the EXACT same as mine. He has the same belt number on the serp as me (did the cross-ref in my head) So, I see no reason at all why they won't work on yours Stony. They literally took me about 10 minutes to change both of mine. 1 nut, loosen the the tensioner head bolt, slip the belt off. Loosen the idler bolt. Reverse for installation. You can do that!!! I BELIEVE <img src="/forums/images/graemlins/lol.gif" alt="" /> I have about 40 miles on my set-up now and it's made a difference in the noise level and I can definitely see the benefit in having the bearings sealed as opposed to the OE design.
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: hazy_daze] #819768 06/21/07 02:42 AM
87Montero Offline
I will bring the idlers off my SR when I come up keith if I have a chance to remove them. They were nice and quiet during the short while I was driving that truck.. I'll be happy to pass them along if you can't find any new ones.
I don't mean to be anal about replacing them.. but if yours are original there is nothing wrong with a little PM and a nice quiet motor in a truck. Plus.. with deleting the cost of labor, it makes it worth doing all the PM you can. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: 87Montero] #819769 06/21/07 07:03 AM
If you get time, bring 'em...I'll BUY them. The guy at NAPA said he had no clue what an M10 washer was...I figured I can see what size I need once I get the old pulleys off.
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: stony-man] #819770 06/21/07 01:07 PM
hazy_daze Offline
Good grief <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Tell him the Rockford # is 2808-010. It's just a flat washer for a 10mm Metric bolt, gosh. It ain't rocket science. You'll need 10 of them, as well as the (2) 38042 pulleys.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6471 MB (Peak: 0.7579 MB) Data Comp: Off Server Time: 2026-07-17 01:04:27 UTC
