Re: Kinda Urgent: Need tensioner pulleys for my V6
[Re: justice]
#819751
06/19/07 05:16 AM
There was a thread around Jan this year. I replied to it. My pullies were from Autozone. I think they were around 16.00 each. 48 hr delivery.
92 Montero LS, Rancho Shocks, Hellas, AirLift bags, 99 Superduty 7.3, Rancho 9000s, Superchip, Banks Billet Torque Converter, AirRaid, BFG's, Pillar Guages, 4.5" Exhaust
[Re: hazy_daze]
#819753
06/19/07 07:18 AM
If the tensioners just need the bearings, see if grainger or an industrial supply can get them. The pulleys are usually ok, it's the bearings that give out on em. Give that a try, may save ya some moolah <img src="/forums/images/graemlins/kewl.gif" alt="" /> what ? have they seized, or making noise or what ? perventative maintenance ? it is my alternator bearing (I guess) that are screaming ....and big mean dogs hear it and start to chase me. Has anyone changed those bearings? I looked at the manual, and it appeared do-able. I am afraid I will get it apart and need a special tool to get it back together
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: generation_one]
#819754
06/19/07 07:29 AM
I just replaced my tensioner pulley but it was my Alt making all the noise. Stony, I can overnight you my old pulley which is actually good if you want it. Let me know. <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 Montero LS 24V DOHC 3.0L. 98 Montero 24v SOHC 3.5L, factory rear locker, Winter/tow package. 63 Jaguar XKE 3.8L FHC 2000 Mercedes-Benz e430 07 fj cruiser
#819755
06/19/07 12:46 PM
I'll cross this number to a NAPA # when I get to work, and order one from ATL if I don't have one in stock. I'll also check to see if there is one that is a more direct replacement (ie no washers) I'll post up the info later today.
[Re: hazy_daze]
#819756
06/19/07 01:07 PM
There should be some numbers on the bearings that can be cross refenced at some place like Applied Industrial, Motion Industries, Grainger, even McMasterCarr.
[Re: Dan1171]
#819757
06/19/07 03:51 PM
AFAIK Volkswagen 4-cyl tensioner pulleys are identical.
1989 Exceed LWB 4m41 (3.2DiD TurboDiesel 5-spd Manual Tranny 2" lift 31" BFG A/T
[Re: Boertjie]
#819758
06/19/07 04:21 PM
I crossed the Goodyear # to a NAPA TEM 38042. With the five M10 washers behind it, it does work. I just put it on mine and ran it for a bit. The only concern is the lack of inner lip. Doesn't appear to be necessary, though. The grooves are located and tracked by the crank, fan and alternator <img src="/forums/images/graemlins/kewl.gif" alt="" /> If there's any way this thread can be archived for future reference, that'd be great. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: hazy_daze]
#819759
06/19/07 07:10 PM
The contact surface of the pully for the belt is slightly convex and is enough to keep the belt centered. Sure beats the dealer charges doesn't it!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: RDB]
#819760
06/19/07 07:16 PM
At $12.76 apiece, ummm... yeah <img src="/forums/images/graemlins/lol.gif" alt="" />
