someone help me identify this hose? (or lackthereof heh) #821017 06/25/07 01:43 AM
ChrisH Offline OP
someone with a 22re do me a huge favor and tell me what this hose fitting is and more importantly where the hose is supposed to go to? I searched and searched and couldn't find the hose anywhere in there so I'm assuming it's either really hid in the back of the motor or there's another fitting in need of a hose as well.
Thanks guys!
I've circled the fitting in the first two pics, and my middle finger is resting on it in the third.
(click the link below each image for a full size version if you'd like)
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: someone help me identify this hose? (or lackthereof heh) [Re: ChrisH] #821018 06/25/07 02:16 AM
ToyinAround Offline
Are you sure it was even hooked to anything? I've had a few trucks with 22RE's and i've seen 1 or 2 of those nipples plugged. Do you have cruise?
1987 4Runner SR5,SAS,6 inches of lift,35in BFG's,Welded Front,Detroit E-Z locker V-6 Rear, 5.29's
Re: someone help me identify this hose? (or lackthereof heh) [Re: ToyinAround] #821019 06/25/07 02:34 AM
ChrisH Offline OP
it's definitely got vacuum i can hear it with the hood closed that's why i checked it out in the first place.
i'm not positive it had a hose but when i put my finger over the hole and plug the vacuum the idle goes down a little. figured that meant that *something* is awry.
btw sweet bumper. looks great.
Re: someone help me identify this hose? (or lackthereof heh) [Re: ChrisH] #821020 06/25/07 02:45 AM
yotaman7 Offline
On my 93 22re which is a california model, one hole is plugged, the second goes to the vsv that controls the fuel pressure regulator, and the third one goes to the vsv that works with the EGR.
My bet is that hole should just have a plug on it unless cruise control has something to do with it. Have you looked at the vacume system routing info on the underside of your hood. That should tell you if anything should go there.
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: someone help me identify this hose? (or lackthereof heh) [Re: yotaman7] #821021 06/25/07 03:10 AM
4Crawler Offline
My '85 has one line plugged out of that fitting as well:
http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/10.html
One goes to the VSV for the fuel pressure regulator and one goes to the cruise control servo. I used the 3rd port (originally plugged) for my vacuum gauge.
Re: someone help me identify this hose? (or lackthereof heh) [Re: 4Crawler] #821022 06/25/07 03:35 AM
MAC Offline
My 87 22re non-california has two of the three ports plugged...but in any case it should not be open to atmosphere.
Re: someone help me identify this hose? (or lackthereof heh) [Re: ChrisH] #821023 06/25/07 07:41 AM
stock87 Offline
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: someone help me identify this hose? (or lackthereof heh) [Re: stock87] #821024 06/25/07 07:52 AM
toyotaguy55 Offline
plug that ***** up <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
Re: someone help me identify this hose? (or lackthereof heh) [Re: toyotaguy55] #821025 06/25/07 04:37 PM
Scerb Offline
Do a carb swap
Re: someone help me identify this hose? (or lackthereof heh) [Re: Scerb] #821026 06/25/07 07:07 PM
mqm Offline
The vaccum hoses are crossed up. The vaccum hose to the left of that nipple should be on the one you are pointing too.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6364 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-06-05 18:05:19 UTC
