22re stalling under throttle
#821288
06/26/07 05:18 PM
not my truck, but a friend of mine's '93 22re pickup.
runs ok at idle. snap the throttle and it stalls. can bring up the RPMs slowly, but it begins to break up at higher revs.
no CEL. no codes.
any ideas? still need to get a timing light and fuel pressure gauge on it, but timing WAS ok. and fuel filter is not plugged.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod. -'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: 22re stalling under throttle
[Re: eightyeight]
#821289
06/26/07 05:55 PM
Vacuum leak? Especially around the rubber connectors for the air tube.
[Re: Staceman]
#821290
06/26/07 05:59 PM
possible. i guess that was checked already, but i will look again.
-matt
[Re: eightyeight]
#821291
06/27/07 02:31 AM
Make sure the TPS is set up properly; root of all evil.
Might also have a plugged EGR.
[Re: kewlynx]
#821292
06/27/07 02:37 AM
Yes, if you don't find any vacume leaks I would check the egr system. The symptoms sound like that of an egr problem. Someone gave me a 92 saturn sl2 not to long ago because if you tried to accelerate it would cut out and stall, but if you reved it real slow it would rev up. So it was basically imposible to drive. Turned out to be the egr valve itself. Got it runnin good and sold it before somethin else broke on it.
[Re: yotaman7]
#821293
06/27/07 03:19 AM
Starving for fuel. Change fuel filter.
Keep the Shiney Side up. Support our troops.
[Re: canuck]
#821294
06/27/07 05:19 AM
no codes... x2 on fuel Low fuel pressure? ...weak fuel pump or clogged filters.
good luck
1991 FJ 80 Land Cruiser for fun. 1998 GS300 for the wife 1998 GS400 for me 1991 Supra SOLD 1986 4Runner 335k miles-22re EB inside.SOLD
[Re: Frank Torres]
#821295
06/27/07 03:56 PM
fuel filter is ok. still need to check fuel pressure. dosen't seem like an egr problem to me, but i will block it off an see if it changes.
it acts exactly the same whether tps is plugged in or not. it is entirely possible that the tps is bad, but i don't think it's the only problem.
-matt
