Page 3 of 3 1 2 3
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: JLEMOND] #822399 08/03/07 04:42 PM
NATO308 Offline
I replaced the rear main seals on one of my Rodeos and two of my Amigos. I did not drop the transmission, just moved it back enough to get to the seal, about 4 to 6 inches. This did not leave any room to "drive" the seals in place so I made up an aluminum tool and used four bolts screwed into the drive shaft to "press" the seals in place. I used a heavy aluminum industrial temperature sensor cover that fits the seal perfect. I drilled four holes in the cover using the flex plate to mark the position for the holes. Bought four bolts 55 mm long, it worked great to evenly press the seal in place. Pictures if you need them. Also have access to a few more of these covers fairly cheap.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: NATO308] #822400 08/04/07 12:56 AM
JLEMOND Offline
THAT IS A SUPER IDEA IF YOU CAN GET IN THERE , ONLY DOWN SIDE IS IF THE FLYWHEEL LANDS ON YOUR TOP SIDE , GETTING THAT THING BACK UP OVER YOUR HEAD IN THAT SHORT OF A SPOT ,DONT LET IT SLIP.. JERRY
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5941 MB (Peak: 0.6425 MB) Data Comp: Off Server Time: 2026-06-17 13:45:40 UTC
