Page 3 of 3 1 2 3
Re: Removing Doors for First time...Please pass on any tricks [Re: BigJim] #822676 07/11/07 01:11 AM
2000Trooper Offline
Over on Palmer and Mopac! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jaime
Re: Removing Doors for First time...Please pass on any tricks [Re: Bigbird79] #822677 07/11/07 06:49 PM
bradford_johnson Offline OP
and WHACKS the butt end with a BFG! This motion causes the bit
Hee hee big jim you mean a BFH not a BFG. <img src="/forums/images/graemlins/lol.gif" alt="" />)
What the hell is BFH?
2004 TJ Wrangler Sport
Re: Removing Doors for First time...Please pass on any tricks [Re: bradford_johnson] #822678 07/11/07 06:59 PM
2000Trooper Offline
Big Freaking Hammer
Jaime
Re: Removing Doors for First time...Please pass on any tricks [Re: bradford_johnson] #822679 07/11/07 11:38 PM
Bigbird79 Offline
Its a very percisely calibrated tool. LOL <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Removing Doors for First time...Please pass on any tricks [Re: Bigbird79] #822680 07/12/07 01:13 AM
Easy to say, hard to do correctly I guess. My Torx connectors (3 of the 4) are now stripped. I pounded as best as I could to cement the torx into the connector, but to no avail. At the first turn of the socket wrench, it spins and disengages stripping the connector. I've already purchased replacement connectors, but how do I get them out?
Re: Removing Doors for First time...Please pass on any tricks [Re: bradford_johnson] #822681 07/12/07 01:29 AM
BigJim Offline
When messing with one of them bolts I always take a small pointed object and completely CLEAN out the torx holes...COMPLETELY.. Then I use the hammer driver on them.
If the wrench is not bottomed out and seated completely... problems arise.
You may be able to WHACK em to get them broke loose and do a bit of grinding on an oversize tool to meke it a bit smaller and then get it to fight tightly enough to get the bolt out. If not then here comes the "easyout".
If the bolts are on the rollcage or the frame one might be able to grind two parrell sides on the bolt head and get a wrench to fit and unscrew them. Never forget to WHACK em a good whack will break loose the rust and helps most frozen bolts.
Re: Removing Doors for First time...Please pass on any tricks [Re: bradford_johnson] #822682 07/12/07 06:07 AM
Bigbird79 Offline
You stripped them out using a hammer impact driver like this?
http://www.sears.com/sr/javasr/prod...&vertical=TOOL&ihtoken=1
I am a little suprised, but like Jim said, if you didn't have the Torx bit fully seated in the screw/ bolt, its not hard to do. Allen scres/ bolts are just as big of a pain.
Re: Removing Doors for First time...Please pass on any tricks [Re: Bigbird79] #822683 07/12/07 03:37 PM
My period of shame continues. It was the paint I feel, that prevented the Torx connector pin from fully seating, and in the end stripping my Torx connectors. To prevent myself from doing any further damage, I plan to visit a local body shop and pay to have them removed, and the new replacements I purchased (without any paint) installed.
Re: Removing Doors for First time...Please pass on any tricks [Re: bradford_johnson] #822684 07/12/07 09:55 PM
Bigbird79 Offline
Thats a bummer, yeah you really have to get everything out of screw head first, it doesnt matter if you are dealing with an Allen, Phillips, Torx or a Straight slot. I would be very careful about putting non coated screws/ bolts back in, I would at least put a good coating of Anti-seize on the threads to combat any future removals.
Sean
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6333 MB (Peak: 0.7380 MB) Data Comp: Off Server Time: 2026-06-10 01:31:08 UTC
