Re: carburator float chamber gas level drops...then hard start [Re: Davepet] #822698 07/06/07 05:35 AM
Vanishing_Point Offline
Carb rebuilding tips:
Keep it clean.
Don't strip screws!
Keep organized. Egg cartons and ziplock bags work well. Take pics.
Be carefull how you remove gaskets! I actually polished some gasket surfaces with a dremel and rubbing compound.
Anybody thought of putting teflon tape on threaded parts?
Re: carburator float chamber gas level drops...then hard start [Re: Vanishing_Point] #822699 07/06/07 05:40 PM
stock87 Offline
If someone ever figures out how the heck these things leak down, please let me know.
I've set one out completely disassembled and filled it with water and I couldn't get the level to drop, and yet the last 4 I've put on my truck easily lose half an inch or more in just a few hours after it's parked.
It makes no sense because every fuel outlet from the bowl (aside from the AP and AAP) come up above the fuel level. And I can visually verify neither of the pumps are leaking.
I have fuel gremlins stealing my gas!
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: carburator float chamber gas level drops...then hard start [Re: stock87] #822700 07/06/07 07:46 PM
W
Whizkidder Offline
Fuel molecules are smaller than water molecules, so gas will leak where water won't. That said, any chance this is evaporation (possibly helped along by heat after the engine is shut off)?
Re: carburator float chamber gas level drops...then hard start [Re: stock87] #822701 07/07/07 05:20 AM
Davepet Offline
I did the same thing & never found the source either.
In answer to the other post, this wasn't evaporation, as it would happen even if I only started up long enough to fill the bowl.
Dave
Re: carburator float chamber gas level drops...then hard start [Re: Davepet] #822702 07/07/07 05:35 AM
W
whitetoy Offline
I do not have that problem with mine.
Next morning, the truck starts instantly.
My carb has a drain plug at the bottom of the bowl,
that if you loosen, it drains the bowl completely.
Could it be leaking on yours?
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6123 MB (Peak: 0.6767 MB) Data Comp: Off Server Time: 2026-07-17 02:19:34 UTC
