Page 3 of 3 1 2 3
Re: T-Case ... need options... [Re: 4xToy] #822751 07/15/07 03:41 PM
RobG Offline
I've seen RobG's pics but they don't explain the details.
Well, thats because the details are pretty simple. Take a 5spd MUA5 w/ intergrated tcase, remove the output flange. Then take an isuzu divorced style tcase from behind an automatic, and its input shaft will slide right on to the output shaft of the MUA5. Then all you need is the fabrication to hold the two together and to get the front output of the MUA5 out of the way to make room for the driveshaft.
The idea is pretty simple, putting it into practice does require some cleavor, very custom fabrication.
-Rob
Re: T-Case ... need options... [Re: RobG] #822752 07/15/07 04:55 PM
houlster Offline
Isuzu Moderator
These are some pics I took when I was working on the same. These are the rear half of a *fixed output* manual tranny & the front half of the auto tcase that would go behind it.
With the fixed output, you have about a 13/16" gap between the cases for an adapter plate. I do think it'd be a good idea though to cut off a half inch or so of threads from the rear output of the front case so you can get more spline engagement. You'll end up with a thinner adapter plate, but you can give up a lot of the 13/16" in that area. I did rough cut an adapter (no pics) and ground off a little of the rear output to close the gap enough that I could use 3/4" plate for the adapter. You could cut more and use 3/8" - 1/2" plate as well. That's still plenty thick and gives you better spline engagement.
This last one is two auto tcases behind a 4l60. This was just a mock up to check driveline length. It's way too long for an Amigo, but a Rodeo/Trooper could do it.
--Dan
Re: T-Case ... need options... [Re: houlster] #822753 07/24/07 03:10 AM
trav Offline OP
Thanks dan... That is really helpfull.
Has anyone done this on a 2nd gen?? I know that there are some differences in the trannys and the cases... but are they essintally the same as far as input/output??
1998 Isuzu Rodeo -- slightly modified.
Re: T-Case ... need options... [Re: trav] #822754 07/24/07 05:57 AM
maxwell417 Offline
I am browsing www.car-part.com looking at transfer cases from 2.8 v6 with AT. Is there really a difference between t-cases with the option code 6NZ? 6nz is the wide tire option.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: T-Case ... need options... [Re: maxwell417] #822755 07/24/07 06:48 AM
94rodeo Offline
The auto t cases I am using on my projects are from 93 plus rodeo's and troopers.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: T-Case ... need options... [Re: trav] #822756 08/10/07 11:52 AM
Bansil Offline
Is there a way to tell,or what to look for to find a fixed yoke case?
Besides looking under the vehicles?
I have a couple auto t-cases but my 5spd is slip yoke and I want to change the back half to fixed yoke.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: T-Case ... need options... [Re: Bansil] #822757 08/10/07 01:41 PM
RobG Offline
from Jerry...
ALL RODEOS FROM 93 UP WITH A V6 4X4 USED THE FIXED YOKE , THE ONLY ONES THAT HAD A SLIP YOKE WERE THE 2WD UNITS,, THERE WERE 2 DIFF JOINT SIZES FRONT TO REAR , BUT FOR THE MOST PART ALL THE REAR SHAFTS USED THE 1310 JOINTS , ALLSO ALL TROOPER FROM 92 AND UP AUTO OR MANUAL HAD A FIXED YOKE , I THINK I HAVE SOME OF THOSE 1310 YOKES IF YOU CANNOT FIND ANY UP THERE , BUT THE DRIVE SHAFTS ARE ALUMNIUM, ALLSO ALL THE AXIOM 4X4 HAD THE FIXED YOKE
-Rob
Re: T-Case ... need options... [Re: RobG] #822758 08/10/07 03:53 PM
houlster Offline
Isuzu Moderator
The '94 Amigo went to fixed yoke as well and possibly some '93's that were built late in the year.
If you have a donor auto t-case, you can swap the guts & rear cover to an MUA-5 to get a fixed output on that. The only downside is the auto t-cases have a different side tooth count on the gears and don't seem to use synchros, so you will loose them in the MUA. I liked having them for the Hi-Low shift will moving, but for some people it really doesn't matter.
--Dan
Re: T-Case ... need options... [Re: trav] #822759 08/10/07 05:54 PM
Bansil Offline
thanks guys.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.037s Queries: 15 (0.013s) Memory: 0.6387 MB (Peak: 0.7453 MB) Data Comp: Off Server Time: 2026-11-02 14:22:30 UTC
