tire questions #823348 07/05/07 07:44 PM
I
irish_ROCKS Offline OP
31x10.5 tires on my 91 sr5 xcab 4x4 are shot....even if that 3.4 swap truck im considering works out I cant get it for a couple months.......
http://www.pirate4x4.com/forum/showthread.php?t=592483
33x10.5 bfgs 3/4 tread for 200 bucks
two questions....will they fit without a lift?? my fenders are sawzalled out a couple inches already.....prolly need to hammer over the front fender seam... I know it wont be reall desirable or have much flex......
2 is I have 4.10 gears...........wat would it drive like without a gear swap............33s an 4.10s???
Im just tryin to get this truck by til sept or so when i can get a replacement ........... Thanks y'all
irish kicks ASS!!!!! ;-p
Re: tire questions [Re: irish_ROCKS] #823349 07/05/07 10:06 PM
N
norcalsvx Offline
i run the 33x10.50 with stock gears (22re)and it is pretty slow (even with all my power mods) i had them mounted up before i got the BJ spacers and it rubbed a lot-
1994 toy 22re
Engbldr. street rv head 261c,LC header,Downey dualshocks, BJ spacers, OME torsions, 33x10.50 BFG muds budbuilt xmember/skid plate 4.88's locker custom exhaust
2006 Subaru Forester XT
1994 Subaru SVX
1979 Mazda rx7
Re: tire questions [Re: irish_ROCKS] #823350 07/05/07 11:29 PM
trcdrunner Offline
Should fit - but may have rub issues depending how lose your current set up is...
May give the filled wheel well look
you wont have much 'flex' room...
You can always crank the Tbars up a bit (front) to help clear....
and for rear a set of extended shackles - add a leafs - or blocks (in that order from better to worse)
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: tire questions [Re: irish_ROCKS] #823351 07/06/07 04:11 PM
fourwd1 Offline
33's are going to rub some, and you'll notice a slight loss in power, but if you only need to get by till Sept, don't worry about it.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
PHP: 7.4.33 Page Time: 1.840s Queries: 15 (0.009s) Memory: 0.6009 MB (Peak: 0.6569 MB) Data Comp: Off Server Time: 2026-11-05 07:11:23 UTC
