'86 running rich #823386 07/06/07 02:48 AM
O
opusthe2nd Offline OP
Tail pipe is black. Choke isnt the issue. Any adjustments on these carbs I can make? Any suggestions??
Re: '86 running rich [Re: opusthe2nd] #823387 07/06/07 05:16 AM
myyota Offline
I just bought an 84 4Runner that is also running rich, so today i started digging into it to figure out what was wrong, and i found that the aux accelerator pump (AAP) is leaking fuel into the vacuum lines, so time for a rebuild. check for this problem on your truck.
Re: '86 running rich [Re: myyota] #823388 07/06/07 06:13 PM
O
Wow! Too many wires and vacuum hoses on this thing, way over my head. Time to find a carb with 1 vacuum hose on it, and no wires.
Re: '86 running rich [Re: opusthe2nd] #823389 07/07/07 04:39 AM
cktoy Offline
scerbs carb facts will fix you right up .the only vac you absolutly have to have goes to the distributor.these carbs arent too bad if you take your time .I used to waste a lot of fuel running rich ,my oil smelled like gas too.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: '86 running rich [Re: cktoy] #823390 07/07/07 06:29 AM
O
scerbs carb facts
Whats that?
Re: '86 running rich [Re: opusthe2nd] #823391 07/07/07 01:11 PM
drainsbe Offline
Carb FAQ
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Dave
86 4Runner, 22R-EB
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6058 MB (Peak: 0.6753 MB) Data Comp: Off Server Time: 2026-07-15 17:53:31 UTC
