Re: '97 TJ Getting 8/10 MPG - HELP! [Re: playinmud] #823471 07/08/07 12:26 AM
BobRowe Offline
Assuming you wre only vehicle in the area when you passed the police warning device, I'd r'd think it was more likely that your dad's speedo was off rather than the radar device.
If you have a speedometer shop in your area, it's a fairly quick and easy job to check out the accuracy of your speedo, and they can re-gear it. If not, see if there are measured mile markers in your area and drive by them and check your odometer. Don't just check one mile -- drive thru about 5 miles and see how many miles your odometer has changed during the 5-mile run.
I'd also check the gearing on the differential. Check to see how many times the driveshaft turns during one wheel revolution.
Re: '97 TJ Getting 8/10 MPG - HELP! [Re: BobRowe] #823472 07/08/07 12:45 AM
playinmud Offline
3.07's in the diffs
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: '97 TJ Getting 8/10 MPG - HELP! [Re: playinmud] #823473 07/08/07 03:10 AM
BobRowe Offline
I'm confused... Are you talking about your Jeep now, or are we stil talking about the one asked about by acleme1?
Re: '97 TJ Getting 8/10 MPG - HELP! [Re: playinmud] #823474 07/08/07 04:11 AM
playinmud Offline
my jeep, but im not really worried much about the speedometer, i just go with the flow of traffic, and when no traffics around i drive my own speed limit
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6086 MB (Peak: 0.6635 MB) Data Comp: Off Server Time: 2026-11-18 11:55:07 UTC
