Re: 4d56 or 4m40? [Re: blizi] #823493 07/10/07 02:46 PM
Macka Offline
Thank you for this replies. Are the 4d56's and 4m40's turbochargers same?
probably not, different displacement (engine size), usually means that they use a differnt turbo. Unless of course they are very close close in displacement, then they usually put a different pitch on the turbine vanes to match it to the engine for better effiency.
always working
Re: 4d56 or 4m40? [Re: Macka] #823494 07/17/07 01:04 AM
PartyTruck Offline
{2.5td LWB}. I know that 2.5td which has 99hp is not enough for LWB Pajero, even for offroads.
I beg to differ, in most cases horsepower comes second to low gears. A LWB 2.5 with 5.29 gears is better in very steep climbs than a 2.8 LWB with 4.88 gears, it also gives you the option of using taller tires.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5948 MB (Peak: 0.6438 MB) Data Comp: Off Server Time: 2026-06-20 22:48:42 UTC
