What do I need to do to fit 33's on my TJ?
#823954
07/09/07 11:45 AM
Ive got a 98, and I'm wanting to fit 33's on it.
Currently its stock with 31's. I get no rubbing at all.
So the question is, what can I do to fit 33's under my Jeep? Ive looked at the 2" budget boosts, but from what I can tell, this will not allow me to get the 33's under there? No one has yet to give me a completely straight answer to this question.
If this doesn't allow it, what will?
Re: What do I need to do to fit 33's on my TJ?
[Re: Macdaddy4738]
#823955
07/09/07 03:14 PM
your best bet would be a 4in suspension lift
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
[Re: playinmud]
#823956
07/09/07 04:07 PM
I agree. I have heard of people putting 33's on their TJ with just a 2 inch lift, but I believe that they had some rubbing issues.
If you don't want to get an entire lift, you can always get the budget boost, and also a 1 or 2 inch body lift.
Gun it and run it! 1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
[Re: Brown81CJ5]
#823957
07/10/07 05:01 AM
33's with a two inch lift should fit, but your going to run into rubbing issues, im afraid my 33's might rub on my 4in lift when i got the front sway bar disconnected, its a lot easier to have more then enough room then not enough, more room gives you an excuess to get larger tires in the future
[Re: playinmud]
#823958
07/13/07 12:26 AM
A sawzall. If we always have to lift our rigs so no rubbing occurs. Guys running 40s would have 15+" of lift.
First it is not a disaster to have some rubbing, who cares. A little rubbing to keep center of gravity low is a good thing.
I'm NOT joking regarding a bit of fender cutting to solve slight rub issues.
2" lift and a bit of cutting works.
4" of lift and a little cutting gets 35" tires under there.
SD
