dual row timing chain #824154 07/10/07 06:14 PM
cktoy Offline OP
is the dual row chain kit worth the money? what are the advantages of it.seems like the single row does a pretty good job
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: dual row timing chain [Re: cktoy] #824155 07/10/07 06:28 PM
ACES_HI Offline
You will loose some hp with the two row. Probably less than 10 hp I would guess. Just takes more work to turn the extra chain. Dont know of any advantages.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: dual row timing chain [Re: cktoy] #824156 07/10/07 07:22 PM
P
PETE_YK Offline
Greater strength, longer service interval.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: dual row timing chain [Re: PETE_YK] #824157 07/11/07 12:09 AM
grandeyota Offline
I had a single row chain jump a tooth.
Now this was at ~5k RPM and the chain had broken guides and about 100k on it so all in all I can't complain.
Fur clog in the sausage grinder
Re: dual row timing chain [Re: grandeyota] #824158 07/11/07 02:57 AM
mqm Offline
I have a dual row setup on mine, PO installed it, rest of the motor is stock. Supposed to last much longer than the single row setup. As far as loss of hp's i didnt feel any difference when comparing it to my buddy's 4x4 stock 22re with single row timing chain. Got over 20k on dual row TC, everything looks nice and tight.
Re: dual row timing chain [Re: cktoy] #824159 07/11/07 03:18 AM
engnbldr Offline
>>>*We tested years ago. The results were 6-8 H/P loss from drag. The gains were from more surface area at wear points, thus longer service life.
Pull strength in reversions testing came up zero difference, there is no difference in strength. It is wear points that make the difference, and this is actually quite a bit.
If you don't like opening her up every 120,000 miles or so, which is normal single setup service then the dual roller can be a good investment.
Also a good investment if your use is severe, racing, mud running, etc. You sacrifice a few ponies for being still running at the checkered flag....*EB
*Beats the he** outa me!....*LOL**...
Re: dual row timing chain [Re: engnbldr] #824160 07/11/07 04:05 AM
cktoy Offline OP
ok thanks guys.I think Ill stick with the single row for my needs.just a dd a little offroad on the weekend
oh what a feeling:
84 supra yard art
Re: dual row timing chain [Re: engnbldr] #824161 07/13/07 12:07 AM
mqm Offline
So how much mileage should i be able to get out of the dual TC before i should think about changing it?
Re: dual row timing chain [Re: mqm] #824162 07/13/07 01:59 AM
grandeyota Offline
Almost have 15k miles on my current dual row setup. I'll let you know when it wears out. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: dual row timing chain [Re: grandeyota] #824163 07/13/07 01:16 PM
mqm Offline
Well i know you'll get atleast 22k on it without any probs....thats where im at <img src="/forums/images/graemlins/notooth.gif" alt="" />
PHP: 7.4.33 Page Time: 1.102s Queries: 16 (0.003s) Memory: 0.6354 MB (Peak: 0.7432 MB) Data Comp: Off Server Time: 2026-06-05 07:49:22 UTC
