chevette carb
#824175
07/10/07 07:54 PM
has any one ever put one on the 2.6? what years chevette would have the holley? tia cory
1988 swb montero/pajero 1995 sr montero
Re: chevette carb
[Re: mountain_warrior]
#824176
07/10/07 11:54 PM
Maybe I'm missing something but did the chevette use the 2.6L Mitsu powerplant? I always thought different carbs will only fit certain intake manifolds and they are not interchangeable? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: chevette carb
#824177
07/11/07 12:19 AM
unless you can fab up an adapter plate I would say no
Re: chevette carb
[Re: off-roader]
#824178
07/11/07 02:09 AM
Chevettes boasted the mighty 1.6l engine.
Re: chevette carb
[Re: JohnnyBfromPeoria]
#824179
07/11/07 02:40 AM
Yes, an iconic example of American iron, it was <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: chevette carb
[Re: hazy_daze]
#824180
07/11/07 03:58 AM
yes i found my answer a holley carb out of a 80 or 81 chevette will fit a mitsu 2.6 and by-pass the computer connections cory
Re: chevette carb
#824181
07/11/07 04:14 AM
One of the fastest cars I have ever seen in person was a chevette body/frame and the interior looked nearly stock except the shifter and roll cage.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: chevette carb
[Re: Tag]
#824182
07/11/07 04:36 AM
one of the guys i talked to about getting a carb said his is pushin almost 320hp <img src="/forums/images/graemlins/zombie.gif" alt="" /> cory
Re: chevette carb
#824183
07/11/07 03:52 PM
Chevette transmissions had bearing failures on the average of every 40K, so if some one could get any power from that Opel lump how long would that transmission last?
