knock, air flow meter, and o2 sensors!
#824234
07/11/07 12:50 AM
i had my motor rebuilt and when i got it back my check engine light was on. i checked it out and it was those three things. i changed my o2 sensor and it still says it is bad. dont have an ohm meter to check air flow meter but dont have the money to just change it and the problem not be fixed. havent had time to change the knock sensor yet. truck seems as if it is starving for gas when i push the peddle half way. if i put it to the floor or just barely give it gas no problems. if anyone has any ideas of what to check other than the airflow meter since i do not have an ohm meter i would really appreciate it. thanks.
"IM THERE BUDDY"
Re: knock, air flow meter, and o2 sensors!
[Re: wytee]
#824235
07/11/07 01:17 AM
what model of vehicle, year, engine type ?
Keep the Shiney Side up. Support our troops.
[Re: canuck]
#824236
07/11/07 01:40 AM
that would probably hepl if i told you. its a 88 4x4 22re.
"IM THERE BUDDY"
[Re: 4Crawler]
#824238
07/11/07 02:46 AM
just got done using a friends. nothing went over 25 ohms. not sure if i just did it wrong or the ohm meter is crap. i went by the diagram i was given by u in the past.
"IM THERE BUDDY"
[Re: wytee]
#824239
07/11/07 03:35 AM
i tested it wrong of course and my Vb connection is bad. im not sure where it leads to though. i was told by a friend to check my fuses? good idea or no?
"IM THERE BUDDY"
[Re: wytee]
#824240
07/13/07 04:38 AM
Check fuses, yes, good idea. Call it 30 seconds well spent.
1990 4X4 Pickup V6 390 000 KM Tired engine, 4.10s, and 31" tires Dog, Canoe, ATV
