Swaping out shifter knob #824375 07/11/07 09:06 PM
bradford_johnson Offline OP
I have a chipped shifter knob that is really bothersome. I have purchased a replacement, but can't get the old knob off. What is the trick?
2004 TJ Wrangler Sport
Re: Swaping out shifter knob [Re: bradford_johnson] #824376 07/11/07 09:20 PM
BigJim Offline
Many have a CAP on the top that snaps off and there is a nut under it. Others simply unscrew from the stick.
Re: Swaping out shifter knob [Re: bradford_johnson] #824377 07/11/07 11:02 PM
DBL_DTY97TJ Offline
Yours should have the cap with the shift pattern which will pry out. There is a nut underneath that has to come off before the nob will unscrew.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Swaping out shifter knob [Re: DBL_DTY97TJ] #824378 07/11/07 11:10 PM
Thanks, I didn't know that would pop off. That explains why it doesn't unscrew as expected.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5988 MB (Peak: 0.6542 MB) Data Comp: Off Server Time: 2026-06-17 16:47:54 UTC
