Gear oil coming from front diff vent. Why? #824439 07/12/07 04:45 AM
dougcl Offline OP
Hi folks, it finally dawned on me that I needed to replace my rear u-joints. So I've limped my rig around using front drive only this week while the rear driveline is getting refurbished. I noticed gear oil coming from the front differential vent. My first suspicion is an overfilled diff. But then I say to myself, that's impossible, because you can't really get much more in there than the proper amount without it spilling back out of the filler hole. At least not so much that it comes out of the vent! What gives?
Thanks,
Doug
Portland OR
1980 Toyota 4x4 Pickup
Re: Gear oil coming from front diff vent. Why? [Re: dougcl] #824440 07/12/07 04:56 AM
OOP'S Offline
Do you have your diff breathers extended? If not have you ran through any water lately? They can get over-filled with water if the breathers are not extended. The caps that are supposed to stop that sort of work.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Gear oil coming from front diff vent. Why? [Re: dougcl] #824441 07/12/07 04:58 AM
4Crawler Offline
Could be the vent was plugged and the pressure of the hot oil pushed it open and oil came out. Or there may have been moisture in there and as it boiled out, it took some oil with it.
Re: Gear oil coming from front diff vent. Why? [Re: 4Crawler] #824442 07/12/07 06:59 AM
dougcl Offline OP
Hi guys, thanks for the ideas.
Doug
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-06-06 15:29:03 UTC
