secondary oil pressure outlet? #824634 07/13/07 03:55 PM
huskyohilux Offline OP
Wanted to have both the stock oil pressure sending unit (for a gauge, not a warning light) and the backup electrical installed in the 22r-e block. Tried with a t-connection but it didn't fit the narrow hole in the block (seems to be really small, also tried home three different sending units with the same thread that didn't bite). Read about a secondary outlet by the R engine mount bracket. Does that work and will a OEM sending unit fit in between there?
Re: secondary oil pressure outlet? [Re: huskyohilux] #824635 07/13/07 05:39 PM
SALMONHEAD Offline
The sending unit on my '84 22R is just above the pan, between the motormount and the starter.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: secondary oil pressure outlet? [Re: huskyohilux] #824636 07/13/07 10:15 PM
dcg9381 Offline
PAssenger side motor mount, behind the mount itself..
IT's the same size as the OEM hole.
It's BSP (british standard pipe). Very close to 1/8NPT.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5915 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-06-12 03:09:55 UTC
