1991 Montero 4X4 3.0 SOHC 6G72 #825292 07/16/07 05:06 AM
Hoppy_27 Offline OP
[color:"blue"] [/color] Looking for help on my Montero I just got it from a friend in a trade the motor is Seized up or locked up I was wondering what all you have to do too it to get it running right again or an easy fix..Please Any Help would be appreciated smile Thanks!
Re: 1991 Montero 4X4 3.0 SOHC 6G72 [Re: Hoppy_27] #825293 07/16/07 06:38 AM
torquemonster Offline
if the engine is seized it needs to be pulled out and replaced with a new engine...or rebuilt if its not too screwed up.
Re: 1991 Montero 4X4 3.0 SOHC 6G72 [Re: torquemonster] #825294 07/16/07 06:43 AM
Chris_J Offline
Yep. Pretty much. Go find you another 3.0 to slap in there.
Or an 6.0 what ever happened to that truck?
Re: 1991 Montero 4X4 3.0 SOHC 6G72 [Re: torquemonster] #825295 07/16/07 04:57 PM
Hoppy_27 Offline OP
Is it Hard to get another engine that kind 6G72 cause its 4x4 my friend said he found another one but it was knocking real bad ? And also can u not open it up and oil it or lube it where u can get it running agin or something sorry when it comes to mechanics I am a know nothing..lol
Re: 1991 Montero 4X4 3.0 SOHC 6G72 [Re: Hoppy_27] #825296 07/16/07 06:24 PM
justice Offline
If the engine is siezed, most likely its done, and cant be repaired short of a rebuild. 6G72 is a very common engine. Found in Quite a few dodge and Crysler Minivans, lebarons etc. You could probably find a good bottom end out of one of those..Make sure you keep the Montero engine around to swap all the needed parts over. Also the dipstick is on the wrong side in the Crysler applications so to ease the swap you might want to get it out of another Montero or Mighty max truck..this engine was also in the Mitsu Diamante among others..do some research and look around.
Re: 1991 Montero 4X4 3.0 SOHC 6G72 [Re: justice] #825297 07/16/07 10:13 PM
Seized as in running and just quit, or seized as in sat for a long time and won't turn over now even with a fresh battery, just goes clunk?
It is marginally possible to free up the second kind, but it takes patience and is iffy.
Conclusion: Pull and rebuild or buy used or buy reman. I only recommend #1...
PHP: 7.4.33 Page Time: 2.474s Queries: 15 (0.004s) Memory: 0.6097 MB (Peak: 0.6798 MB) Data Comp: Off Server Time: 2026-06-20 19:31:36 UTC
