Clutch bypass
#825441
07/17/07 12:38 PM
So i'm checkin out my clutch safety switch last night ready to bypass it with a toggle. I found a button sticking out of the bottom of the switch. Is this a factory bypass incase the switch fails? It is a 89 amigo.
Re: Clutch bypass
[Re: frankinpa]
#825442
07/17/07 08:06 PM
Possibly a reset button ?
Larry W - 99 VX s/c 3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
Re: Clutch bypass
[Re: Ldub]
#825443
07/17/07 08:37 PM
Flick the switch and see what happens. Just make sure your not in gear . . .
Re: Clutch bypass
[Re: frankinpa]
#825444
07/18/07 12:58 AM
NO IT IS JUST THE PLUNGER FOR THE SW , IT GOES ALL THE WAY THRU, IT HAS TO MOVE QUITE A BIT ,WHERE IT IS MOUNTED , IT IS THE WHITE PLASTIC PLUNGER IT SHOULD STICK OUT ABOUT 3/8 INCH JERRY
Re: Clutch bypass
[Re: JLEMOND]
#825445
07/18/07 03:11 AM
Thats it, white about 3/8 long.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6656 MB) Data Comp: Off Server Time: 2026-06-24 15:22:12 UTCValid HTML 5 and Valid CSS
