Coolant #825522 07/17/07 09:14 PM
Hydra747 Offline OP
When I run the A.C. After a little while I think that I smell coolant in the cab....Although no leaks.
Could have been my imagination but I thought that some moisture or droplets had sparayed out to the driver (Not sure about this though).
What could it be????????
Re: Coolant [Re: Hydra747] #825523 07/17/07 11:35 PM
Everet Offline
Your HEATER CORE LEAKING <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Guess you'll have to change it out.... <img src="/forums/images/graemlins/zombie.gif" alt="" />
But wait....with cutting out the cover, it won't take as long.<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Mine is doing the same thing.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Coolant [Re: Everet] #825524 07/18/07 04:38 AM
Iron Offline
Took a look at the heater core position, and by using the 'cover cutting' short cut you should be able to access the core with only removing the raido panel, not the entire dash! I will be a guinee pig later this summer to test this theory!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: Coolant [Re: Iron] #825525 07/18/07 08:03 AM
O
oul053 Offline
mine smells of coolant when i turn the heater on, but i pressure tested the system and no leaks checked under the dash no leaks and it doesnt loose any coolant. i put it down to the car having character <img src="/forums/images/graemlins/lol.gif" alt="" />
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: Coolant [Re: oul053] #825526 07/19/07 12:17 AM
DennisThompson Offline
Mine has smelled like coolant when I first turn on the heater since new. 11 years and 160,000 plus miles later stilll no leaks. It must be a Kia Thing, I still don't understand.
Dennis
Re: Coolant [Re: DennisThompson] #825527 09/22/07 01:15 AM
Hydra747 Offline OP
Thanks for the inputs.
No leaks thus far. The smell is still prevelant.
I guess it is a kia thing <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Coolant [Re: Hydra747] #825528 09/23/07 01:15 AM
Cen_Tex_KIA Offline
Mine too. But never found a leak. My wife didn't want me to buy it because she could smell it. 80k miles later, she dosn't mind. Think thats a standard feature. Not a option.
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Re: Coolant [Re: Cen_Tex_KIA] #825529 09/23/07 11:42 PM
Calappoyas Offline
No smell here.I have a passion of hate for leaks of any kind.
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: Coolant [Re: Calappoyas] #825530 09/24/07 08:59 AM
O
oul053 Offline
mine has a smell but no leak, i call it character hehe
Re: Coolant [Re: Iron] #825531 10/08/07 06:48 AM
sjs Offline
Yo, Iron.
Not sure if that is possible but interested to hear about it. Heater core is too long, I think, to clear the dash. But heck, who knows? You might be able to pull the dash clear enough to get the job done without pulling the controls and such.
While you're in there mucking and sweating about in the dash, be sure and meditate how how much it would have cost Kia to provide a couple of screws and a real cover to make it all easier. smile
Lemme know how it works out.
Stanley
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.004s) Memory: 0.6348 MB (Peak: 0.7386 MB) Data Comp: Off Server Time: 2026-06-17 01:25:35 UTC
