front knuckle diagram
#825839
07/18/07 10:43 PM
I'm looking for a exploded view of the front hub on a 89 isuzu. I read in the manual that the front wheel bearing is one piece and has not adjustments? is this right.
Re: front knuckle diagram
[Re: frankinpa]
#825840
07/18/07 11:54 PM
Isuzu Moderator
Nope. You read wrong. The front wheel bearings are not sealed units. Pre-load is adjusted via the spindle nut.
I don;t have a diagram for you, but it is your typical 4wd spindle and hub arrangement.
Michael
[Re: mlclark]
#825841
07/19/07 07:40 AM
[Re: lttlbddy]
#825842
07/19/07 01:26 PM
Does this go for 4wd also? I should have stated it was a 4x4 amigo After i read that i checked advace auto's site and they only listed 2wd bearings no reference to 4wd. Then i checked autozone .com and they listed 1 bearing for somthing in the range of 80.00usd. Next question is there a special socket for the #8 locknut? Or does sombody have a OTC part number?
[Re: frankinpa]
#825843
07/19/07 03:22 PM
I use a crank tool for my bicycle to loosen the nut or a screw driver and my palm.
I believe the above is a 4wd version. The specs I used were for a 1989 Trooper which only came as 4wd.
I got that diagram from myisuzuparts.com
For some reason they don't list the Amigo but the parts are all the same.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6019 MB (Peak: 0.6669 MB) Data Comp: Off Server Time: 2026-06-21 21:01:01 UTCValid HTML 5 and Valid CSS
